can any1 tell me how to take out my stock stereo?
Take out the center console by removing the two pieces. To do that, you remove the two screws, one on either side of the piece with the arm rest (rear console). Then you remove the front part by removing the shift ****, and the two screws under the handbrake under the little plastic tab. There are also two screws at the front of the console close to the passenger and drivers feet.
After you have that done, stick your head under the dash, you will see two screws holding the radio, once you have removed that, the entire radio along with the supporting surround slides foward, and you can remove it. To install an aftermarket radio, you will need some sort of mounting kit.
