DO all 98+ USDM headlights have this problem?
Old Mar 3, 2003 | 05:22 AM
GSblueRacing's Avatar
Default DO all 98+ USDM headlights have this problem?
I noticed that the Driver's side beam angled more toward the ground, I could see a little spot light infront of me, and the Passenger side low beam are more spread out and goes 2 feet+ farther. Is that normal on all 98+ lights?
Old Mar 3, 2003 | 06:06 AM
IntEGNYC's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (GSblueRacing)
try adjusting the headlights. They have X and Y adjustments on the fixtures which will require a philips-head screw driver.
Old Mar 3, 2003 | 06:14 AM
Jesse H's Avatar
Every car is supposed to be setup that way, to reduce glare for oncoming traffic.
Old Mar 3, 2003 | 06:52 AM
migs's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (Jesse H)
JesseH is right
Old Mar 3, 2003 | 07:01 AM
reno96teg's Avatar
Old Mar 3, 2003 | 07:07 AM
MR. ARIZONA's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (reno96teg)
I didn't know EVERYCAR was setup that way...Why is it more noticeable in INTEGRAS than anyother car? My parent's cars don't do that, niether do my friends...JUST MINE....
Old Mar 3, 2003 | 07:22 AM
DR3AM's Avatar
Whoa...I didn't know that. And to think I was getting annoyed because of the lower angled Driver Side headlight....
Old Mar 3, 2003 | 07:31 AM
Chris's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (Gizzzer98)
True, to a certain extent. Yes the pass side is angled more straight and, the drivers side should be angled to the shoulder.
Just to make sure exactly, take the car to a certified lamp adjustment station (most mechanics are "certified")
Old Mar 3, 2003 | 07:32 AM
reno96teg's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (QUICKTEG)
it's more noticable with our projector headlamps..
Old Mar 3, 2003 | 09:08 AM
LsPower's Avatar
Just try adjusting them to your liking. If you dont know how you can probably get a body shop to do it. May charge you though.
Old Mar 3, 2003 | 09:49 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: DO all 98+ USDM headlights have this problem? (LsPower)
mine does that too
Old Mar 3, 2003 | 10:10 AM
Hairy Gorilla's Avatar
Default Re: DO all 98+ USDM headlights have this problem? (dLo GSR)
Yea, it only takes 5 minutes and a screw driver. It's really not hard at all. The lights even have a bubble on them to let you know where they are angled.
Old Mar 3, 2003 | 10:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: DO all 98+ USDM headlights have this problem? (Tim Maryak)
The projector cutoff makes a pronouced pattern visible when the lights are shined on a wall, where the left side is slightly lower than the right side. If you shine your lights on a wall they should look like this:
__________o-------------_____________o-------------
Both headlights have the same cutoff pattern, and the high (right side) of each cutoff should be at the same height.
Old Mar 3, 2003 | 10:39 AM
SIK IN DA HED's Avatar
New User
i didnt even notice that.
Old Mar 4, 2003 | 03:51 PM
Default Re: DO all 98+ USDM headlights have this problem? (SIK IN DA HED)
yeah but how comes my friends 95 teg and another friends 94 teg isn't like that? btw, the bmw, infinitis, lexus, merc. all have projectors, they don't seem to have that kinda setup, meaning they dont' have the drivers side angled lower than the passenger side.. they are somewhat even.
[Modified by GSblueRacing, 12:56 AM 3/5/2003]
Old Mar 4, 2003 | 04:04 PM
black2001gsr's Avatar
Mines like that.
98civdx
Lighting
Apr 1, 2009 02:43 PM
SWE3TDUDE
Oct 3, 2007 04:03 PM
8400rpm
Jul 3, 2006 08:39 PM
91integraLSVTEC
Jun 7, 2005 06:35 AM
DamonBoost
Aug 8, 2002 10:40 PM
