CTR piston compression
Old Mar 3, 2003 | 01:43 AM
bframe's Avatar
From: A place w/o thieves. Wishful thinking, VA, USA duh
Default CTR piston compression
Is there any thing that needs to be done w/ the head of a b16a2 when installing ctr pistons. My research tells me that they have high compression and I want to play it safe as possible. Holla @ me
Old Mar 3, 2003 | 07:36 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: CTR piston compression (bframe)
no
Old Mar 3, 2003 | 07:38 AM
romeo619romeo's Avatar
Default Re: CTR piston compression (vtecvoodoo)
adjust your valves thats about it
Old Mar 3, 2003 | 12:23 PM
B16b2b's Avatar
like he said, no. the compression ratio will not be that high.
Old Mar 3, 2003 | 12:52 PM
00MRSi's Avatar
Default Re: CTR piston compression (B16b2b)
You should be ok. I believe the rods needs to be shaved aprx. 1mm for the pistons. Not totally sure. As always, should check clearances.. CTR pistons with CTR cams seem to be a very nice upgrade for the money.. If you want more power try some Skunk2 Stage 1s or 2s or Toda Bs..
johnzm
566
Mar 19, 2013 05:13 AM
B16A CRX
Apr 6, 2007 06:03 AM
sk8er5150
Aug 21, 2006 03:37 PM
WhoDoYouThink
Oct 4, 2005 01:02 AM
jsalicru
Dec 20, 2002 03:13 PM
