help!!! 5th gen JDM valve cover install
Old Mar 2, 2003 | 10:15 PM
whatsreallygood's Avatar
Default help!!! 5th gen JDM valve cover install
guys, did a search nada....can't get ahold of helms either.....someone who's put on JDM valve cover helpe me with install, my main problem is getting VC off, there is a plastic piece which I cannot get off....the alternator wire is in the way
Old Mar 2, 2003 | 10:25 PM
Jago's Avatar
Default Re: help!!! 5th gen JDM valve cover install (whatsreallygood)
You have to disconnect the alternator wires. The VC just pulls out.
Old Mar 2, 2003 | 10:28 PM
Default Re: help!!! 5th gen JDM valve cover install (Jago)
so only way is to disconnect alternator wire.....IC.....figure that just trying to avoid it, but if its the only way.....thanx JAGO
Old Mar 3, 2003 | 08:19 AM
luderacer's Avatar
You don't have to disconnect the wire but it would be easier if you do. You should be able to take the valve cover with no trouble at all. Easy job.....
KashMillien
Aug 12, 2015 12:55 AM
mac_24_seven
Mar 22, 2013 09:00 PM
whp
Mar 11, 2007 12:53 PM
ITR_1211
Dec 23, 2003 01:43 PM
