Diff Bearing Part #?
Old Mar 2, 2003 | 09:47 PM
Mr_GSR's Avatar
Default Diff Bearing Part #?
As stated in the topic, i got a kazza lsd, now all i need is the part # for the diff bearing does anybody know what it is? Thank you much for any help
Old Mar 2, 2003 | 10:06 PM
Mr_GSR's Avatar
Default Re: Diff Bearing Part #? (Mr_GSR)
hmmmmmmm, mabey it would have helped if i said it was a 97 gsr.......
Old Mar 2, 2003 | 10:16 PM
au-gsr's Avatar
go here order two of the number 17. you may also need to replace the transaxle seals if you don't have new ones sitting at the shop waiting to be installed. that is number 21 order two and any other rubber seal you have pulled you should replace. hope that helps
http://www.acuraautomotiveparts.org/...CLUTCH+HOUSING
[Modified by au-gsr, 11:16 PM 3/2/2003]
Old Mar 3, 2003 | 07:57 AM
Mr_GSR's Avatar
Default Re: Diff Bearing Part #? (au-gsr)
That did help, THANKS A MILLION!
speeddave
Transmission & Drivetrain
Apr 29, 2009 11:35 PM
RicTRD
Jun 10, 2005 02:43 PM
PhantomTEG
Jan 29, 2004 07:16 PM
tvrsir
Apr 25, 2002 09:54 PM
