tranny and clutch Q's
Old Mar 2, 2003 | 08:31 PM
crxdohczc's Avatar
Default tranny and clutch Q's
i had recently swaped my dx crx with a zc and used the old tranny off the dx. and the clutch and flywheel that i just replaced before the swap. now my car wont even go into gear with the car running. now the question is can i use an ingegra (zc) clutch and flywheel with a dx tranny?
91 crx ZC powered without clutch
Justin
Old Mar 3, 2003 | 11:41 AM
tpr's Avatar
tpr
Default Re: tranny and clutch Q's (crxdohczc)
You match the clutch and pressure plate from the transmission (spline count/diameter). If you used the same clutch/pressure plate/flywheel from the DX it should work just fine unless something is wrong with the install. The only thing that comes to mind is if the clutch disk was installed backwards. The disk would interfer with the flywhell bolts. Or possibly too much free play in the cluch cable not allowing the clutch to fully disengage.
Old Mar 3, 2003 | 07:40 PM
crxdohczc's Avatar
Default Re: tranny and clutch Q's (tpr)
got it figured out clutch was messing with flywheel bolts and spun one almost completely out. then to top it all my pressure plate was pushed in and not retracting. so i changed to an integ clutch, integ pressure plate,zc flywheel and dx tranny. mix for the power
91crx-jace
Jan 11, 2009 06:41 PM
weppskilla
16
Mar 7, 2006 02:44 AM
crx69
Apr 10, 2005 05:33 PM
camboMONK
Apr 1, 2003 07:15 PM
