Yet another topic on LS/VTEC
Old Mar 2, 2003 | 06:52 PM
Sassafrass's Avatar
Default Yet another topic on LS/VTEC
OK I did a search and I didn't come across my question there. My questions is Would a c5 head be a better choice then the B16 for the ls/vtec, no matter what head I get it will get Port and Polished and but if I got a c5 head I wouldn't change the cams but if I got a B16 head I would. If I got a B16 head what kind of cams would you recommend? My plans are to use eagle rods and either a forged piston or just CTR pistons, new valve train and fully rebalanced bottom end. any other suggestions?
Old Mar 2, 2003 | 06:54 PM
Chris y0!'s Avatar
Default Re: Yet another topic on LS/VTEC (Sassafrass)
if you are going to P&P and swap cams, get the b16.
and for your application i think skunk2 stage 1 will be a good choice.
Old Mar 2, 2003 | 08:34 PM
splayed's Avatar
Default Re: Yet another topic on LS/VTEC (Spoon Hybrid)
the c5 head is basically the b16 head with a p&p...so just go the cheaper route and get the b16....spend the money on somethin else...
Old Mar 2, 2003 | 09:02 PM
acydphryck's Avatar
i say get the GSR head...it doesn't flow as well as the B16 head but you get more power and torque from the GSR. as far as cams go, it depends on what you wanna use the car for. are you gonna drag it? road racing? daily driven? plan out what you wanna use your car for and then go from there...it's a waste of $$$ and time to buy drag racing cams when you use your ride for auto cross or road racing...
Old Mar 3, 2003 | 07:04 AM
Sassafrass's Avatar
Default Re: Yet another topic on LS/VTEC (acydphryck)
My plan is to daily drive and possible street/track races. I have heard bas things about useing the GSR head, well I guess not bad things but I was directed in the ways of a B16 head.
Old Mar 3, 2003 | 07:28 AM
King Tut33's Avatar
The B18c5 head is far supperior (valves, cams, valve springs). If you can get one, buy it. You can still P&P it and put cams in it or stay stock.
Old Mar 3, 2003 | 07:46 AM
dfoxengr's Avatar
use b16, same casting as ITR..skunk2 stage 2 cams...and fix up the springs/retainers as well...
96int3gra
Jan 22, 2008 06:59 AM
nix94delsol
Jul 29, 2007 06:52 PM
SEXY TIME!
11
Mar 22, 2006 08:44 AM
2gen_tegs_rule
Feb 6, 2006 12:29 PM
AutoTrenz702
Dec 13, 2005 02:44 PM
