Will 92-92 COUPE front bumber cover fit SEDAN
You don't have to change the fenders, although it will fit better if you do.
If you change the fenders, you need new corner lights also, and the hood will not align with the fenders any more (the hood will be too high for the fenders).
the coupe fenders dont work on the four door, the coupe bumper fits, but you have to modify the bumper support, the sides dont match perfect, but probably a heat gun could help
the only part that is perfect is behind the corners, and the 2 dr bumper is shorter and shows the bottom of the rad support
Here's a pic of Rudy's (AKA singlecam screamer) Sedan...
Here alittle more info on it too: https://honda-tech.com/zerothread?id=415986
https://honda-tech.com/zerothread?id=400394
[Modified by JV, 11:43 PM 3/2/2003]
check out mine i did the "conversion". but itll fit but it wont sit correctly. the 2dr fenders are also too short and will leave a gap from ur door to the fender. so in order to make it fit good i put the 4dr fender on, and cut off half on the 2dr fender and welding them together, a custom fender if u will. but i think that its all worth it.
singlecam screamer
14
Jan 31, 2003 04:16 PM
