All Show No Go Decided, Where is ZDYNE Group buy
Old Mar 2, 2003 | 04:51 PM
ScottEK's Avatar
Default All Show No Go Decided, Where is ZDYNE Group buy
I think have just decided to not make my car look nice this summer and instead go forced induction. I saw a group buy for Zdyne a couple days ago but I've searched for the last 10 minutes and no matter what I search for the thread wont come up. I have some other sub questions that are probably very newbie, so while your reading this,
Since a B16 is somewhat high compression will it be necessary to use a different head gasket? The one setup that I saw with stock head/block was running 12-14PSI daily with a Cometic head gasket. Would it be better to use the stock head gasket and 6-8PSI?
Will the ZDYNE Gold eliminate the need for a VAFC?
Is there something cheaper, or better suited for this application than a T3/T4 setup?
When you buy a Zdyne ECU do they keep your old unit as a core?
Thanks
Old Mar 2, 2003 | 05:07 PM
UberTeg's Avatar
Default Re: All Show No Go Decided, Where is ZDYNE Group buy (beta13)
Zdyne wont work with a b16 ecu, so i hope ur still using your old ecu.
Old Mar 2, 2003 | 05:30 PM
CRVRX's Avatar
Default Re: All Show No Go Decided, Where is ZDYNE Group buy (UberTeg)
As a core you will need to supply a 88-91 crx Si or HF computer.
You will be fine at your stock compression , You will be able to run 12 psi no problems at all, it's all tuning and you will have all the tunning you need.
I have tuned many B16As and a B18C5 with the Zdyne. The B18C5 is stock compression and runs 10-12 psi daily.
Not sure about the Group buy though, Order it right from Z-dyne then you know what you are getting.
Old Mar 3, 2003 | 10:45 AM
ScottEK's Avatar
Default Re: All Show No Go Decided, Where is ZDYNE Group buy (CRVRX)
Anyone have the link to the group buy?
Old Mar 3, 2003 | 01:52 PM
RAWB's Avatar
Zdyne GB thread CLICK THAT
[Modified by RAWB, 3:22 PM 3/3/2003]
Old Mar 3, 2003 | 01:53 PM
tegman2's Avatar
Search on http://www.g2ic.com I thought I saw one on there.
Aron
Old Mar 3, 2003 | 06:36 PM
ScottEK's Avatar
Default Re: All Show No Go Decided, Where is ZDYNE Group buy (RAWB)
You rock, I dont get why searching for ZDyne doesn't work, is this search actually case sensitive. Thank you so much.
buddy190
Feb 10, 2009 05:51 PM
b18delturbo
14
Mar 16, 2006 09:53 AM
NoDestinationSi
Jun 1, 2005 05:40 PM
E Swift
Nov 15, 2002 07:31 AM
