2 boxes vs. 1 for two 10 inch subs
Old Mar 2, 2003 | 04:33 PM
JOMO
Guest
Posts: n/a
Default 2 boxes vs. 1 for two 10 inch subs
i got 2 kickers, i was gonna get a big ported box and put the 2 in them but im thinking of getting 2 smaller boxes so i can position them to sound better, i drive a hatch and i figured i could twist and turn them to my liking, boxes will be built by a proffesional...
kicker impulse if youre wondering
Old Mar 2, 2003 | 06:53 PM
JOMO
Guest
Posts: n/a
Default Re: 2 boxes vs. 1 for two 10 inch subs (JOMO)
i got a suggestion for 2 one foot sealed boxes...any comments?
Old Mar 2, 2003 | 09:01 PM
JOMO
Guest
Posts: n/a
uhh.*bump*
Old Mar 2, 2003 | 10:25 PM
t0p_sh0tta's Avatar
there is a huge difference between ported and sealed boxes. When you decide which one you want let us know.
[Modified by t0p_sh0tta, 8:44 AM 3/3/2003]
Old Mar 3, 2003 | 08:11 AM
hs2000's Avatar
go with one ported one sealed, thats what I would do if I was using two subs but I choose Quality over Quantity.
[Modified by hs2000, 5:12 PM 3/3/2003]
Old Mar 3, 2003 | 08:34 AM
t0p_sh0tta's Avatar
Default Re: 2 boxes vs. 1 for two 10 inch subs (hs2000)
That would sound like *** unless you know what you are doing. There are ABC boxes which can yield similar results to what I think you're trying to accomplish, but they are a bit tricky to build.
Sealed or ported. Choose one or the other...
[Modified by t0p_sh0tta, 12:37 PM 3/3/2003]
Old Mar 3, 2003 | 03:41 PM
JOMO
Guest
Posts: n/a
Default Re: 2 boxes vs. 1 for two 10 inch subs (t0p_sh0tta)
could you explain the main differences, i just want it to bump hard, sound quality is an issue but ill deal with that later...i just want SPL
thanks
Old Mar 3, 2003 | 04:46 PM
t0p_sh0tta's Avatar
If you want it to bump hard then you want a ported box tuned somewhere around 40-45hz. What kind of car is this going in?
Check out this page: http://www.eatel.net/~amptech/elecdisc/
You'll can learn just about everything you need concerning car audio there.
Old Mar 4, 2003 | 08:30 AM
JOMO
Guest
Posts: n/a
well, they are in a swift gti hatch back,. i have them in a custom parcel shelf facing upwards and i like how they sound there, but someone on tempro told me the subs suspension was made for a sealed box, not ported, im confused, im gonna try and get both and switch them amd see what happens
thanks
Old Mar 5, 2003 | 08:18 PM
JOMO
Guest
Posts: n/a
c'mon, help me out
Old Mar 5, 2003 | 11:11 PM
Bassicfun's Avatar
stick with one box... Sealed.. be sure each speaker is sealed from each other.. ALSO be sure you are properly powering them via their RMS wattage..
As a BASS PLAYER For many many years... a car audio guy for plenty of years.. and just simple physics.....
Bass (low frequency) is omnidirectional... so the direction they are facing isn't that important.. be SURE they have airspace to compress infront of them.. the other advantage of ONE sealed box, is keeping the subs from interfearing with each other.. to have that low of a frequency heading towards each other as if you were to have 2 boxes and have each sub face the other is in all reality going to create a muddiness to the sound more then anything...
Plenty of boxes built, systems installed.. and experiments done... this is all true.
Old Mar 6, 2003 | 05:12 AM
JOMO
Guest
Posts: n/a
Default Re: 2 boxes vs. 1 for two 10 inch subs (Bassicfun)
thanks man!
im gonna try that but the subs are in my parcel shelf now, i was gonna build a box in that...
hmmm
fryman
Audio / Security / Video
12
Jun 27, 2008 01:05 PM
MAX PAYNE
Aug 15, 2006 11:25 PM
SantaCruz92Si
Jul 1, 2003 02:06 PM
GroundZer0 336
Apr 3, 2003 10:32 AM
1BlackHatch
Mar 19, 2003 12:09 PM
