oil lines,fittings ect to complete custom set up
i am doing a custom setup and i have everything i just need the componets for oil feed and return. it is for a b18c1 i have a Golden Eagle Turbo Oil Feed Kit i just need to know legnths for oil lines and what size fittings and style etc someone that has done this befor would be a great help thanks.....
you just need a 1/8" to -3AN adapter from the GE adapter kit...you need to cap the other -6 closed unless you're running an LS/VTEC or etc..
I cna get you the oil feed line and oil return kit to work with the GE adapter plate...
IM me
stan
BTW: if you;re doing it on your own, I always sell the oil feed line kit with a 43" of goodridge SS lines...long enough for you to pull the turbo/manifold out then undo the oil feed line form the turbo
[Modified by Flamenco-T, 9:48 PM 3/2/2003]
IM me
stan
Acura_I-RS
Mar 9, 2003 09:59 PM
