got an idea but its probably been done before.......
Old Mar 2, 2003 | 07:20 AM
buckfittyone's Avatar
Default got an idea but its probably been done before.......
has anyone tried to modify the stock shocks to work with coilovers by shortening the shiny piston rod? it seems like if the rod was half if its length it would work with coilovers wihout blowing or leaking fluid,
your thoughts ideas and comments are all welcome i want to know if im onto a decent idea
Old Mar 2, 2003 | 07:23 AM
Patron's Avatar
Default Re: got an idea but its probably been done before....... (buckfittyone)
you're decreasing the travel on the shock, it would ride like ****.
Old Mar 2, 2003 | 07:33 AM
SebAyatollah's Avatar
Default Re: got an idea but its probably been done before....... (ptran13)
coil over = **** ride as it is . i had coilovers on my 90 hatch and i made the mistake of using coilovers on my new porject which is a 93 dx hatch ... next project im going with springs
Old Mar 2, 2003 | 07:43 AM
pennies_hatchie's Avatar
Default Re: got an idea but its probably been done before....... (SebAyatollah)
just buy aftermarket shocks and save yourself the headaches in the future...
ex: tokico, kyb agx, koni yellows, etc.
Old Mar 2, 2003 | 09:21 AM
deepnite's Avatar
finally some people are wising up to this
unless the coils are progressive expect a shitty ride..a stiff ride gets tiring after an hr on the interstate
Old Mar 2, 2003 | 10:02 AM
tominos's Avatar
even if you cut it, the spring rate is still too high for the stock shocks.
Old Mar 2, 2003 | 10:20 AM
OC 335i's Avatar
Not necessarily. It depends on how stiff the shocks and what spring rate the springs are. You cannot make such a blanket statement.
FYI, my APEXi Worldsport "Coilovers" (Dampers) ride like a dream in my 99 Hatch.
Old Mar 2, 2003 | 10:25 AM
sacrilege's Avatar
Default Re: got an idea but its probably been done before....... (MEGA EK)
My Apexi worlsport's also ride very nicely. I think it has a lot to do with the setup though, because I know two friends who bought the same ones a while back and couldn't get them to ride smoothly.
Old Mar 2, 2003 | 10:54 AM
TRENDSETTLER's Avatar
Default Re: got an idea but its probably been done before....... (pennies_hatchie)
Old Mar 2, 2003 | 12:08 PM
Adriano's Avatar
Default Re: got an idea but its probably been done before....... (TRENDSETTLER)
[quote]has anyone tried to modify the stock shocks to work with coilovers by shortening the shiny piston rod? it seems like if the rod was half if its length it would work with coilovers wihout blowing or leaking fluid,
[quote/]
I just got back from Brazil this week (6 weeks vacation in the beautiful wheater). Over there, a lot of people do that to their cars. It doesn't ride that bad. A couples of my friends do that to use with lowering springs. It's doesn't cost that much over there (like $40-50 for all four). Over here it probalby wouldn't be worth the money.
Old Mar 2, 2003 | 12:27 PM
Default Re: got an idea but its probably been done before....... (brryder)
when i first installed my coilovers i liked the way they felt with the stock shocks,but it was only a matter of time before they blew out and it started riding like **** i still want to use the coils with a stock set of shocks,im just trying not to blow the next set
Old Mar 2, 2003 | 12:30 PM
wHOAlly's Avatar
stock shocks do not dampen enough for high spring rates that lowering/coils have
Old Mar 2, 2003 | 12:34 PM
ive still heard of people blowing aftermarket shocks on coilovers because the lowered springs makes the shock sit too low for too long my theory was to balance out that problem by shortening the shock rod
Old Mar 2, 2003 | 03:07 PM
ridiculous's Avatar
yea, i got coilovers, and i love them. i wouldn't mind some aftermarket shocks though!
98 hatch
Feb 6, 2011 06:27 AM
EK9Undisputed
Oct 5, 2008 03:31 PM
Green_EX
Aug 3, 2003 01:22 PM
B_1_8_hatch
Dec 4, 2002 08:15 PM
