Changing Timing Belt
Old Mar 2, 2003 | 06:24 AM
devonic's Avatar
Default Changing Timing Belt
Well i finally got the tool that allows you to remove the timing belt, a harmonic damper pulley puller but i was wondering which way to twist it to get it loose? car is a 97 civic dx.
or does anyone know a link or anything info for changing timing belt? torque lbs/ft? etc..?
Old Mar 2, 2003 | 06:31 AM
hatchdrvr's Avatar
Default Re: Changing Timing Belt (devonic)
It is threaded normally, lefty loosy, righty tighty Good luck, I did mine last weekend and it was a bitch.
Old Mar 2, 2003 | 06:43 AM
devonic's Avatar
Default Re: Changing Timing Belt (hatchdrvr)
ok thanks man, we busted 2 bits last night trying to loosen it.\
which part do you twist lefty to loosen both? the inner bolt and the outer part the pulley puller holds onto?
[Modified by devonic, 3:44 PM 3/2/2003]
Old Mar 2, 2003 | 08:30 AM
NiiS's Avatar
There's an entire thread dedicated to this:
https://honda-tech.com/zerothread?id=425924
Old Mar 2, 2003 | 09:40 AM
devonic's Avatar
Default Re: Changing Timing Belt (sinister)
thank you sinister, i looked but didn't come across that thread
Old Mar 2, 2003 | 09:51 AM
Ricey McRicerton's Avatar
make sure you tighen the crank pulley bolt back down to what they say to...one of my friends thought he could leave it a little loose and lost his crank pulley driving down the highway!
Old Mar 2, 2003 | 12:48 PM
devonic's Avatar
Default Re: Changing Timing Belt (Ricey McRicerton)
ok thanks
anyone know the torque specs for that bolt when im all done?
Old Mar 2, 2003 | 01:09 PM
Evs-One's Avatar
Solbros Owns Me
as tight as you can get. I believe it's around 150 ft pounds, but reef on it till it's solid.
Old Mar 2, 2003 | 03:54 PM
Pele's Avatar
Default Re: Changing Timing Belt (Emerica)
Use an impact gun and it's not a problem.
My father invested in a portable 4 gallon air compressor and an impact gun specifically for the crank pulley on his Saab 9000 Turbo. I have my own impact gun from having been an apprentice auto mechanic last year.
Once you get air tools, you never go back.
Once you've used a lift to do oil changes, You're gonna wish you had one in your garage... Even though you can do your timing belt without a lift, it's so much easier to do it with one.
Old Mar 2, 2003 | 05:28 PM
ZUL8R's Avatar
Default Re: Changing Timing Belt (Pele)
when should I change it out?? got almost 70,000 on my 98 civic. Is it past due? we do Auto-X it a few times amonth so its ran a little harder than mormal.
jaxflex
Feb 24, 2016 02:17 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
spooncivic1
Oct 4, 2004 06:03 PM
Spade
Acura TL, RL & ZDX
Jan 1, 2004 06:26 PM
VisualEcstasy
Apr 23, 2003 02:16 PM
