Type R Injectors
Old Mar 2, 2003 | 06:10 AM
MidoriEK4's Avatar
Default Type R Injectors
i was wondering if i could use type r injectors? would all i have to do is swap plugs and injectors or will need something else?
DaN
Old Mar 2, 2003 | 06:16 AM
USDM 4G VTEC's Avatar
Default Re: Type R Injectors (NA CRX Si)
on a CRX Si??
no they wont work
the 4G and 2G CRX injectors are 1.5-3.5 ohms resistance....
the other injectors are 10-13 ohms resistance....
they will work , but they will fry ou tin a matter of weeks.... that happedned to me when i used the Z6 injectors...
i think in ur case u will have to take the injector resistor off..... but why do that for just injectors....
i am not 100% sure about the ITR's but all honda injectors are 240cc except the preludes that are 270cc......
Old Mar 2, 2003 | 06:31 AM
MidoriEK4's Avatar
Default Re: Type R Injectors (USDM 4G VTEC)
ok cool. what about those prelude injectors? will those work as plug and play?
Old Mar 2, 2003 | 06:36 AM
well honda injectors have diff plugs.... u will need to modify ur existing harness to accept those injectors....
but tis the same deal as the others..... diff in ohms.... not going to work unless i think u take the inj resistor off.... but then the injectors on years change from peak and hol dto saturated... wich isnt a big of a deal , bc under load they get the same signal and response.. the ohms matters bc u dont wanna be frying out 90 dollar injectors just for the fun of it
Old Mar 2, 2003 | 09:07 AM
MidoriEK4's Avatar
ok man thanks for the info.
DaN
Old Mar 2, 2003 | 10:13 AM
EG8R's Avatar
Will Z6 injectors work without a resistor box???
Old Mar 2, 2003 | 02:53 PM
zCivic's Avatar
Default Re: Type R Injectors (mr. skelly)
Z6 will work but you still need to remove the injector resitor box. 92-96 Preludes are aprox 340 the plugs should be the same and there low resistance injectors so you dont have to rewire/remove the injector resistor box.
RACEPAK
Apr 29, 2010 01:42 AM
RACEPAK
Apr 29, 2010 01:41 AM
A13sechatch
Mid-Atlantic (Sales)
May 25, 2009 08:26 PM
dominate9
May 16, 2005 05:38 AM
simple4012
Sep 3, 2002 07:11 PM
