Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What are the correct Lugnuts to use for Kosei K1's on a Honda?
Old Mar 2, 2003 | 04:40 AM
VTECAcuraGSR's Avatar
Default What are the correct Lugnuts to use for Kosei K1's on a Honda?
GUys,
Can someone please tell me what I am suppose to use for lugs on my Kosei Rims that I bought used? Here is a link for reference.....
http://www.prestigewheel.com/Image4502.asp#Extended
Thanks Guys!
Old Mar 2, 2003 | 05:44 AM
jc836's Avatar
Default Re: What are the correct Lugnuts to use for Kosei K1's on a Honda? (VTECAcuraGSR)
Depends on what you want to do-race, street or show. I use nothing but McGard Spline Drive lugs on my AR wheels and they will also work on the stock Honda rims as well. The Kosei is a wheel that I will assume the stock nuts should work on-but check with TireRack first to be sure.
Old Mar 2, 2003 | 06:21 AM
Default Re: What are the correct Lugnuts to use for Kosei K1's on a Honda? (George Knighton)
I do not care about show at all... This is for HPDE/Autocross only
Old Mar 2, 2003 | 08:03 AM
Anyone?
Old Mar 2, 2003 | 08:14 AM
DB2-R81's Avatar
25 Year Member
12 X 1.25, 60 degree conical if you have not changed your hub studs and you have not ruined your K1’s by using some thing else already.
Old Mar 2, 2003 | 12:18 PM
Default Re: What are the correct Lugnuts to use for Kosei K1's on a Honda? (DB1-R81)
Can anyone else confirm this? Thanks!
Old Mar 2, 2003 | 12:34 PM
Reid's Avatar
Global Moderator
Yes, he is right.
Old Mar 2, 2003 | 02:47 PM
Default Re: What are the correct Lugnuts to use for Kosei K1's on a Honda? (Reid)
I used the link as a reference, but are there any suggestions for the best lugs?
Old Mar 2, 2003 | 03:51 PM
AcuraRacer112's Avatar
what is the part number for the McGard Spline drives that fit k1s for my GSR...forgot to order mine and cant figure out the damn websites explination for the application on my car...im looking for the flat blacks without the wheel locks.
Basically asking are cone seats going to work for my application...tia
Old Mar 2, 2003 | 05:18 PM
Tyson's Avatar
any one of those 60 degree lugnuts will do.
Old Mar 2, 2003 | 07:50 PM
philstireservice's Avatar
Hondas and Acuras take 12mmx1.5...............make sure you have the right ones!!!
Old Mar 3, 2003 | 03:00 AM
Default Re: What are the correct Lugnuts to use for Kosei K1's on a Honda? (Maxx44)
Good point Maxx44,
I was just snooping around some more and many people say that they are 12mm X 1.5. So what exactly are stock GSR lugs? Thanks!
Old Mar 3, 2003 | 07:12 AM
Mojo-Jojo's Avatar
I'm using the McGard spline drives too. Works just fine.
Old Mar 3, 2003 | 08:10 AM
Geezer's Avatar
I've been using the part# 5555 lug nuts from Prestige - Extended Conical Seat Bulge Nuts (Open End) in 12mmx1.5. At $0.57 each, might as well go ahead and order a box of 100 to avoid the $10.00 small order fee for orders under $50.00.
teeho
Nov 18, 2007 03:19 PM
backyarddc5
19
Oct 10, 2004 05:45 AM
speedevo
May 12, 2003 08:51 PM
tilt
Feb 11, 2003 10:23 AM
qwklude82
Jan 22, 2003 07:40 AM
