VAFC Hack guys... CEL 43 at partial throttle, cruising?
Old Mar 1, 2003 | 11:34 PM
M-EJ1's Avatar
Default VAFC Hack guys... CEL 43 at partial throttle, cruising?
Background details: I'm running DSM 450cc's with the VAFC hack, D16Z6 turbo'ed with the greddy kit at about 6psi. I had some problems when I first got it up and running with the hack that seemed to be that the car was running EXTREMELY rich. I had a finicky, stuttery idle and my autometer A/F was almost always reading full rich all the time. I checked my timing a couple days ago and found to be extremely advanced while idling (like 22 or so degrees). I backed it down to about 14 degrees, and the rich running ordeal seemed to disappear when I did this. It's now running fairly well (idle is still not what i want it to be, and it is a little lean on the top end (detonation), but it runs and doesn't take a quarter tank of gas to go 30 miles.
Anyway, this CEL has just recently started coming on, while I was running really rich and also after I fixed the timing (and rich problem apparantley)/
Anyone else get this occasionally? I can't seem to find any rhyme or reason to it, but every once in a while (meaning once every couple of days or so) I throw a CEL while just cruising, not boosting or pushing it hard or anything, just driving along. I've had it happen driving slowly in the city at a steady pace, and also driving 60 on the highway.
I believe it's CEL 43, when I check the code it flashes 4 times slowly then 3 times quick. According to my Chiltons manual code 43 is "Fuel Deliver System error" or something like that.
Anyone else ever get this?
Old Mar 2, 2003 | 02:59 AM
Jared's Avatar
Default Re: VAFC Hack guys... CEL 43 at partial throttle, cruising? (M-EJ1)
The most common cause of that is an O2 sensor that is either cycling slow or going out of range. Throw a new O2 in it, you may have fouled it with all that extra fuel.
Old Mar 2, 2003 | 05:23 AM
Joseph Davis's Avatar
Default Re: VAFC Hack guys... CEL 43 at partial throttle, cruising? (Jared)
Yep, what he said.
I've clicked a code 43 a time or two myself. If you boost a bit more frequently, it seems to keep the O2 sensor a bit cleaner and the ECU less prone to click a 43.
FYI, I only have that problem at sea level... with how my setup and tune continually changes, that dosen't really mean much.
[Modified by J. Davis, 6:26 AM 3/2/2003]
Old Mar 3, 2003 | 02:21 PM
torkcm's Avatar
I had the same problem. I couldnt figure out what it was. wasnt boosting and threw too lean/rich code. took out my o2 sensor and it was pretty fouled from running rich, I just cleaned it by take a butane soldering iron from radio shack and attached the torch tip and heated the tip until it was clean looking. Worked fine since.
Old Mar 3, 2003 | 03:14 PM
C_hyrbid's Avatar
Default Re: VAFC Hack guys... CEL 43 at partial throttle, cruising? (J. Davis)
HAHAHAHA, oh ****.... *MrPibb soda comes gushing out of my nose**
NICE SIQ J. davis.. ahah
"i would ******* have sex with a man if he could make my car rwd and boosted with a huge intercooler" - Uberteg
AHAHA, then go read Ubertegs sig and it says
"I'll let anything with a vaj anally penetrate me if they feel they must, though" - Joseph Davis
Man, between both of those sigs, i dont know what i would choose... I know god damn it wouldnt be the first one.... Second one, maybe if she bought me dinner.. AHAHAH
Old Mar 3, 2003 | 04:28 PM
UberTeg's Avatar
Default Re: VAFC Hack guys... CEL 43 at partial throttle, cruising? (C_hyrbid)
Dont lie, you kno u want a rwd boosted car
Old Mar 3, 2003 | 05:56 PM
Default Re: VAFC Hack guys... CEL 43 at partial throttle, cruising? (UberTeg)
Anything for a good vaj
Old Mar 3, 2003 | 06:35 PM
vtecpwred's Avatar
Get Hondata problem solved.
mikeunreal2
29
Mar 22, 2006 06:26 PM
1.8Tities
Jun 7, 2003 06:26 PM
M-EJ1
Mar 6, 2003 09:59 PM
Hellz99si
Sep 23, 2002 05:20 PM
