how hard to get a NA d16a6 into the 14's with stock block?
Old Mar 1, 2003 | 03:14 PM
90da4dr's Avatar
Loved
Default how hard to get a NA d16a6 into the 14's with stock block?
I've finaaly decided on what swap to get. It will be a d16a6 with headwork and si transmission. What else do you think is need to get into the 14's.
Already got intake, header and exhasut
89 civ hatch dx
[Modified by 89civ, 7:21 PM 3/1/2003]
Old Mar 1, 2003 | 05:01 PM
Malgerus's Avatar
Default Re: how hard to get a NA d16a6 into the 14's with stock block? (89civ)
Good tires, hella light car, good driver. Just practice a lot.
Old Mar 1, 2003 | 05:04 PM
EP3_05's Avatar
Slicks, nice cam, valvetrain, and headwork, put the car on a diet. With a good launch you should be in 14's pretty easily.
Old Mar 1, 2003 | 05:22 PM
Broken Gearbox's Avatar
Default Re: how hard to get a NA d16a6 into the 14's with stock block? (91civic)
B series throttle body, D16A6 pistons and rings, D16Y8 intake manifold, thiner head gasket Z6 or Y8, new cam...go check out http://www.exospeed.com and of couse a lot of weight reduction
Old Mar 1, 2003 | 08:41 PM
DsMWookie's Avatar
Default Re: how hard to get a NA d16a6 into the 14's with stock block? (x lP lL i c i t)
in a 91crx SI lightly gutted.....with exhaust,short ram intake, and NGK wires ran 15.3 friend drove the **** out of that car.....runs consistent 15.5's but that was good night 14's very easy bud....snag some pistons and cam gear...
Old Mar 1, 2003 | 09:21 PM
G2turbo_terror's Avatar
Default Re: how hard to get a NA d16a6 into the 14's with stock block? (FMX)
using a z6/y8 head gasket should bring you c/r up around 10:1
Old Mar 1, 2003 | 09:58 PM
Default Re: how hard to get a NA d16a6 into the 14's with stock block? (G2turbo_terror)
the A6 will also bump up the CR also
damn just go check out https://honda-tech.com/zerothread?id=335078 lots of info on d16s
Old Mar 2, 2003 | 05:44 AM
ExospeedAMcrx's Avatar
<---- bone stock A6 bottom end. Exospeed headwork and cam(no milling), bolt ons, weight reduction and slicks. 13.6@99mph 35mpg daily driven.
smokeyjpn221
56
Oct 9, 2009 04:51 AM
dohdoh420
Jun 6, 2006 02:48 PM
Kaan
Dec 15, 2005 05:35 AM
HBK
Sep 18, 2004 06:17 PM
