Where the hell is the MES connector??????
Old Mar 1, 2003 | 02:31 PM
lahight's Avatar
New User
Default Where the hell is the MES connector??????
Can someone please put up a pic or give a detailed explanation of where exactly the mes connector is on a 95 EX? Please, there so many conflicting descriptions. It is definitely a two prong connector correct? Please help.
Old Mar 1, 2003 | 04:14 PM
GimpyAccord's Avatar
Default Re: Where the hell is the MES connector?????? (lahight)
If you're reffering to the service jumper (to check codes, set timing etc) on most 5th gens I've seen that is below the glove box usually in a little blue holder (unless you've had it out before and just left it hanging). If thats not what you're looking for please clarify and I'll try to help!!
[Modified by GimpyAccord, 5:15 PM 3/1/2003]
Old Mar 1, 2003 | 04:32 PM
carolinaACCORD's Avatar
Default Re: Where the hell is the MES connector?????? (GimpyAccord)
yes, gimpy is right. its under the glovebox, in another connector. just look up in there and pull it out. its only a 2 wire plug.
Old Mar 1, 2003 | 08:29 PM
Chiovnidca's Avatar
No, he's after the memory erase signal (MES) connector. It's used for eraseing SRS codes. It's on the left side of the dash near the fuse box. It will have either two gray wires, or one black wire and one white wire.
Old Mar 1, 2003 | 10:10 PM
Default Re: Where the hell is the MES connector?????? (Chiovnidca)
Funky!!!! and now I know.
no SRS equiped accord unfortunatly in my garage... or fortunatly that is.
Old Mar 1, 2003 | 11:29 PM
lahight's Avatar
New User
anyone have any pics or a more detailed description, i have been breaking my damn neck under there and i cant find it
Old Mar 3, 2003 | 01:13 AM
lahight's Avatar
New User
please, anyone?
Old Mar 4, 2003 | 01:06 PM
lahight's Avatar
New User
bump
Old Mar 4, 2003 | 01:48 PM
Default Re: Where the hell is the MES connector?????? (D16Chiovnidca)
wow, i never knew that. i always thought of that as the MIL service check connector.
Old Mar 4, 2003 | 10:09 PM
lahight's Avatar
New User
I know someone knows the answer and has time to waste....
Old Mar 5, 2003 | 10:37 AM
subnet's Avatar
Here you go...
MES 90-97 Accord at right bottom edge of dash.
[img]c:\mes.jpg[/img]
Here's the URL http://alflash.narod.ru/honda.htm
[Modified by subnet, 2:40 PM 3/5/2003]
[Modified by subnet, 9:01 PM 3/5/2003]
Old Mar 6, 2003 | 01:02 AM
lahight's Avatar
New User
Default Re: Where the hell is the MES connector?????? (subnet)
Thanks!
94CoupeEJ1
14
Jan 1, 2013 01:59 AM
codybuRr
14
Feb 7, 2011 05:26 PM
crist488
Lighting
Jan 8, 2010 09:55 AM
jdmland
Sep 9, 2007 08:48 AM
delsoldude
Audio / Security / Video
Nov 14, 2004 09:44 AM
