B18A build up?
Old Mar 1, 2003 | 02:12 PM
Peters1983's Avatar
Default B18A build up?
I have a B18A that I am rebuilding and I would like your suggestions on what I should use. the engine is going into my 91 hatch and I want to builfd it for auto cross and be able to compete on the strip. any suggestions are greatly appreciated.
Old Mar 1, 2003 | 06:35 PM
ihaterice's Avatar
Default Re: B18A build up? (Peters1983)
here is the ultimate b18 non vtec setup imo:
- .025" overbore ctr pistons
- shotpeed ls rods
- crower 404 cams
- crower valve springs
- crower retainers
- skunk2 intake manifold
- jdm 4-1 header
- cam gears
- vafc
- chipped ecu (just to remove rev limiter)
- TUNING!!!
That would be a killer setup, engine would have about 11.2:1 or so compression which would work great on pump gas, the overbore/compression would give you good low end torque and you would also have great top end power with the cam/compression combo.
james
jun6755
Jul 25, 2011 04:52 AM
99siRACER
Jul 1, 2011 05:35 AM
94cpe
Dec 18, 2009 06:28 PM
acuraqc
Jan 13, 2004 08:41 AM
allmotoryea
11
Sep 6, 2003 01:55 AM
