STD hb meets b16a....help!
Old Mar 1, 2003 | 02:04 PM
swaplighter's Avatar
Default STD hb meets b16a....help!
im in the process of wiring my newly installed b16. my problem is that its an STD model (dual point injection) ((2 injectors)). i have a body harness for a crx si. what do i need to do in order to get this thing wired. i know about wiring the vtec, knock sensor etc...WHAT DO I NEED TO DO?!?!
thanks for any help!!
Old Mar 1, 2003 | 02:25 PM
matt j's Avatar
Default Re: STD hb meets b16a....help! (swaplighter)
search for mpfi swap
Old Mar 1, 2003 | 02:39 PM
Default Re: STD hb meets b16a....help! (mattED6)
hmmm no help. thanks anyway.
Old Mar 1, 2003 | 04:14 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Two sites that might help:
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
http://www.angelfire.com/d20/hcivic88/4gtech_vtec.html
Have fun.....
Old Mar 1, 2003 | 04:26 PM
Default Re: STD hb meets b16a....help! (dgonzals)
thank you dgonals!! good info.
Old Mar 1, 2003 | 04:30 PM
dgonzals's Avatar
I am in the process of doing the same thing....So we are on the same page here....Good luck....
Old Mar 1, 2003 | 06:31 PM
RenoRacing's Avatar
here's one my friend made: evilxkid
Old Mar 1, 2003 | 10:12 PM
projecthybrid04's Avatar
Ship your B16 and stock wire harnesses to HAsport and they will mate them together so all you do it plug them into your strut towers and change the pins out on the ecu. There website is http://www.hasport.com. Thats what I did. Good luck!!!
Old Mar 1, 2003 | 10:43 PM
Hybrid Invasion's Avatar
2 suggestions:
1: buy an injector resistor box off of ebay, as you will need that to wire for an mpfi swap like the b16.
2: just get the dx-SiR conversion harness from HAsport, as projecthybrid04 suggested(www.hasport.com). I didn't want to mess with the wiring, and IMO it was worth the extra money to go with that. No wiring needed if you go that way; it's plug and play from there on out.
[Modified by Hybrid Invasion, 2:45 AM 3/2/2003]
Old Mar 2, 2003 | 07:29 AM
Default Re: STD hb meets b16a....help! (Hybrid Invasion)
well ****. i just spent over an hour pulling the whole thing out.
Old Mar 2, 2003 | 08:10 AM
The wiring is the hardest part, **** me and my dad spent two 6 hour days but we had already put the motor in the car and we had to solder some wires because we bought a used Hasport wireharness that had some broken clips, it was definetly the hardest part and figuring out how to change the pins in the ecu was tricky but after that, it's all worth it bro, VTEC is fun and my car is stock on the outside so nobody knows i have it. And when i give my friends rides, they **** there pants because they can't believe my car can go this fast. Good luck.
Old Mar 2, 2003 | 08:39 AM
well thats still not a bad thing; you would need to do that anyway to send your original engine harness, along with the b16a harness, off to HAsport, so if you choose to do that, you're one step ahead. If you choose to wire it yourself, I'd imagine it would be easier to wire everything with the original harness off of the engine, so don't worry about it.
Old Mar 2, 2003 | 08:57 AM
GlowingRotorsXSI's Avatar
yeah, hasport will combine the two harnesses tovgether for 249.00 i think. it says on their site. they do excelent work.IMO keep us posted
Old Mar 3, 2003 | 12:14 AM
RenoRacing's Avatar
Default Re: STD hb meets b16a....help! (ShoeBoxRacer90)
everyone overestimates the amount of wiring required, it seriously takes like 30 minutes, 5$ in supplies, and half a brain to add/modify less than 10 wires. Just don't be intimidated by it!!! good luck!
Old Mar 3, 2003 | 12:41 AM
Timmayeg's Avatar
New User
Default Re: STD hb meets b16a....help! (HavokRacing)
yea i did it it was very easy!!!!
here is the link to do all the MPFI stuff. that chart above is hella nice!!!!!!
http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
then all you have to do is add vtec and knock
http://www.hasport.com/Tech/Wring/88...20to%20B16.PDF
eagleclawracing
Mar 15, 2007 05:45 PM
fastguy8
Aug 9, 2006 12:01 PM
Juan Q...
Jun 28, 2004 08:56 PM
2ndGenREX
Jun 5, 2003 06:59 PM
PimpTightSi
Jan 21, 2003 11:25 AM
