FS: Tamiya TG10 NSX .12 in very good condition any resonable price in the mid $350's+
FS: A Tamiya TG10 from a very good friend of mine he said any price in the 400's to 340's is ok. It's a .12. It's been cleaned further than in the picture.
. It has a custom painted NSX raybrig body and new wheels and tires. It's gone through less than 18 tanks. Cleaned and after run oil used after each run. Air filter always kept clean and IT HAS NO BROKEN PARTS. Comes with every thing to use as shown in the picture the gone through 3 tanks of the new gallon 10% Traxxas top fuel, 500cc fuel bottle, blazer sport radio with 2 servos, custom Raybrig body, tuned pipe deflector, glow plug ignitor and the car. Have any questions email me at
savageaction@prodigy.net or contact me at http://www.savageaction.com. You can find me as the Administrator; neuspeed. Remember it has a
body.
It features shaft driven 4WD TG10-Mk.1 Chassis Sturdy double deck frame consists of 2.5mm duralumin lower deck and reinforced nylon upper deck. Powerplant features a 2.1cc Tamiya FS-12LT engine. Easy to operate system features handy recoil starter. Equipped with four ball bearings for efficient power transmission. Highly efficient large size disk brakes. Double wishbone independent suspension with four high performance oil dampers provides excellent wheel-to-road contact.
Chassis Type: TG10-Mk.1
Scale: 1/10
Overall Length: 435mm
Overall Width: 194mm
Chassis Weight: 1640g
Wheelbase: 257mm
Tread - F/Rr: 155/64mm
Tire Width/Diameter - F/R: 27/65mm
Gear Ratio: 8.1:1
Body: Polycarbonate
Frame: 2.5mm thick duralumin chassis plate with double deck
Suspension: Four wheel independent double wishbone system
Engine: FS-12LT Engine Included
pics:
. It has a custom painted NSX raybrig body and new wheels and tires. It's gone through less than 18 tanks. Cleaned and after run oil used after each run. Air filter always kept clean and IT HAS NO BROKEN PARTS. Comes with every thing to use as shown in the picture the gone through 3 tanks of the new gallon 10% Traxxas top fuel, 500cc fuel bottle, blazer sport radio with 2 servos, custom Raybrig body, tuned pipe deflector, glow plug ignitor and the car. Have any questions email me at savageaction@prodigy.net or contact me at http://www.savageaction.com. You can find me as the Administrator; neuspeed. Remember it has a
body. It features shaft driven 4WD TG10-Mk.1 Chassis Sturdy double deck frame consists of 2.5mm duralumin lower deck and reinforced nylon upper deck. Powerplant features a 2.1cc Tamiya FS-12LT engine. Easy to operate system features handy recoil starter. Equipped with four ball bearings for efficient power transmission. Highly efficient large size disk brakes. Double wishbone independent suspension with four high performance oil dampers provides excellent wheel-to-road contact.
Scale: 1/10
Wheelbase: 257mm
Gear Ratio: 8.1:1
Body: Polycarbonate
pics:
pli
Nov 10, 2006 12:57 PM
