warped REAR rotors??
Old Mar 1, 2003 | 12:49 PM
stockgreencivic's Avatar
Default warped REAR rotors??
Here the problem. Whenever i drive, i get a sounds like something is rubbing. THis sound doesn't happen though when i turn left or when i brake. It sounded like it was coming from the rear so i jacked up my car and span the tire. The tire doesn't spin evenly, sorta like resistance and then no resistance and continues. When i brake there is NO shuddering. Is this a sign of a warped rear rotor??? Let me know, thanks.
Old Mar 1, 2003 | 12:57 PM
Chris y0!'s Avatar
Default Re: warped REAR rotors?? (stockgreencivic)
yeah, change your pads and rotors homeboy, shouldn't be more than 50 bucks.
Old Mar 1, 2003 | 03:22 PM
Default Re: warped REAR rotors?? (Spoon Hybrid)
This is true even though there is no suddering during braking?? Just wonna make sure so i don't change parts i don't need to.
Old Mar 1, 2003 | 03:47 PM
joe_bocc's Avatar
If the wheel spins like you said it did then it is most likely a warped rotor. The reason you don't feel if shuddering might be becasue its in the rear and gets less load when you braking. I bet if it was the front you would feel in shuddering.
babzog
Honda Civic (2001 - 2005)
May 22, 2008 09:49 PM
Chuckles99SH
Sep 27, 2006 02:13 PM
Krnbk2
May 28, 2004 12:47 PM
PatrickGSR94
May 25, 2004 10:18 AM
Backmarker
18
Jun 25, 2002 01:45 PM
