Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Steering Wheel Lock Removal
Old Mar 1, 2003 | 11:50 AM
krbobcat's Avatar
Default Steering Wheel Lock Removal
Can you guys help me out with this? I did a search and didn't come up with anything.
What have you found to be the easiest way to remove the steering wheel lock (per SCCA rules)? I've never had to do this myself so I'd appreciate some help. Also, it's on a '92 Civic. Thanks!
Old Mar 1, 2003 | 07:45 PM
Balled S2K's Avatar
Default Re: Steering Wheel Lock Removal (krbobcat)
https://honda-tech.com/zerothread?id=403366
https://honda-tech.com/zerothread?id=235559
Old Mar 2, 2003 | 04:27 AM
krbobcat's Avatar
Default Re: Steering Wheel Lock Removal (Balled S2K)
ok, i see that i needed to change Data Set to Archived Topics.
Old Mar 2, 2003 | 09:31 AM
Vracer111's Avatar
Just to let you know what I did - I used a cut-off wheel to slice the heads off the two bolts holding the ignition onto the column and about thirty seconds later there was no steering lock.... of course I'm going with custom ignition system so removal of the stock system was all that was needed for my integra's steering lock removal. The links posted should help you out if you are keeping the stock ignition system.
Peruviann
Oct 6, 2007 08:55 PM
hondahp21
Audio / Security / Video
Nov 18, 2006 08:09 AM
ek_will
Dec 29, 2005 07:45 PM
ludedudeh23
Oct 29, 2004 04:33 AM
phantom_sol
Aug 29, 2003 12:54 PM
