Zc guys
Old Mar 1, 2003 | 09:14 AM
cr-x si's Avatar
Default Zc guys
when i swap in my zc what do i do w/ the 2 cam angle sencor wires? I forgot?
Old Mar 1, 2003 | 09:48 AM
Malgerus's Avatar
Default Re: Zc guys (cr-x si)
I'm not a ZC guy but I know this...
You extend the wires to reach the ZC's exhaust cam, where the sensor is located.
Old Mar 1, 2003 | 10:47 AM
Hondasaurs's Avatar
Yes, you exteend them to the exhaust cam. They will be on your distributer plug. If you are doing a MPFI swap you will have to run them from the ECU.
Old Mar 1, 2003 | 02:35 PM
AbaZ's Avatar
Just match the wires from the si/hf plug..
2 wires off the cam angle sensor..
blue/green and blue yellow (technically they are suppose to be shielded) then just tap them into each other. I recommend a quick solder job and some heat shrink.
Jeff
89hbcivicguy
Nov 21, 2007 02:12 PM
QuickStyle
Feb 10, 2007 06:57 PM
stw88crx
Mar 15, 2005 07:07 AM
*Boostwerks*
Mar 7, 2004 06:50 PM
l
Feb 19, 2002 09:00 AM
