fiberglass bumper w/ paint need to remove questions
Old Feb 28, 2003 | 09:23 PM
bhaz413's Avatar
Default fiberglass bumper w/ paint need to remove questions
sup all, i have a question. I recieved a fiberglass bumper for my civic from a friend, and it is not the same color of my car. What i need to know is, what would be the proper way to remove the oil paint?
If I use a solvent, what would be a good one to use?
Or if I used sandpaper for it, what grit should i start with, and work my way up to for a smooth finish?
Thanks guys for all your help!
Old Feb 28, 2003 | 11:46 PM
philly-O's Avatar
Default Re: fiberglass bumper w/ paint need to remove questions (bhaz413)
you dont need to completely remove the old paint unless it is peeling or in bad shape. all you should need to do is to scuff the old paint and paint over it. maybee a little bondo or extra sanding if there are any imperfections in the old paint. goodluck.
Old Mar 1, 2003 | 06:39 AM
bhaz413's Avatar
Default Re: fiberglass bumper w/ paint need to remove questions (peichie)
well the reason i wanted to remove all the old paint was, there are some spider cracks, and there is 1 4 inch crack, and i wanted to see what i am working with and use bondo on it to fix it.
Snailor Built
Oct 30, 2014 02:51 PM
thatcivic96
Paint and Body
Jan 18, 2012 06:05 PM
EJ8mike
Paint and Body
Aug 6, 2011 03:29 PM
Ruben19
Sep 14, 2006 03:32 PM
syoh
Feb 7, 2005 12:57 PM
