Is fuel pressure supposed to drop after shut off?
Old Feb 28, 2003 | 04:53 PM
technine's Avatar
Default Is fuel pressure supposed to drop after shut off?
My fuel pressure drops off to 0psi after a few hours. Isn't it supposed to hold pressure while shut off or does it loose pressure over time. I think I might have a loose clamp, but I don't think I am leaking any fuel. If this is normal than I guess everything might be OK. I also notice a slight stumble while accelerating/cruising all of a sudden and my a/f guage starts going leaner than normal, but after a second the stumble goes away and the a/f goes back to normal. Guess I am leaning out somewhere and maybe it's related to the fuel pressure and a leak maybe? TIA
Old Feb 28, 2003 | 07:46 PM
d-wreck's Avatar
Default Re: Is fuel pressure supposed to drop after shut off? (technine)
it doesnt really matter if it holds pressure for long periods of time. ..
but you sure as hell want it to hold pressure for short amounts of time like anything less then a 1/2 hour, which would mean a leak.. .
when you turn your key to the "ON" position right before the starter turns the motor over you can hear a sound that goes something like. . .
ffffffffffffffkunk
thats your fuel system being pressurized before it starts, so it really doesnt matter, if you had a leak youd know if fo sho
derek
Old Feb 28, 2003 | 09:11 PM
civbeater90's Avatar
Default Re: Is fuel pressure supposed to drop after shut off? (d-wreck)
to drop down is normal
Old Mar 4, 2003 | 12:03 PM
technine's Avatar
Default Re: Is fuel pressure supposed to drop after shut off? (civbeater90)
thanks for the info guys. I'm gonna tighten the clamps just incase.
B16aSir2
16
Aug 30, 2017 05:42 AM
3easy21
Aug 2, 2013 05:48 PM
rdssk8rcs1
Oct 2, 2010 07:41 AM
_jester_
Aug 10, 2003 10:26 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
