ctr..orItr...???
Old Feb 28, 2003 | 04:40 PM
NCHATCH's Avatar
Default ctr..orItr...???
which is better for a street application, ITR or CTR cams going into a B16, or are a set of GSRs any good to use over the stock B16 cams.
mike
Old Feb 28, 2003 | 04:45 PM
Spade's Avatar
Default Re: ctr..orItr...??? (NCHATCH)
default answer: CTR
The GSR's will help a little but, just save your money for the CTR's.
Note: 01 ITR and CTR cams are the same.
The CTR and ITR exhaust cam have always been the same (if you can save a little money do it right?)
Old Feb 28, 2003 | 05:33 PM
Spartanic's Avatar
They should all perform great on the street
Old Feb 28, 2003 | 05:39 PM
migs's Avatar
Default Re: ctr..orItr...??? (Spade)
I thought CTR cams were similiar to that of Skunk Stage 2.
Old Feb 28, 2003 | 05:43 PM
TRENDSETTLER's Avatar
Default Re: ctr..orItr...??? (Migs)
i dont think so...last dyno i saw was ctr vs. sk2 stage1 and stage1 dynoed 8 more hp over ctr.
but to answer your question ctr would be the way to go...also like stated above try to find an itr exhaust cam and use a ctr intake...could save you a few bucks
Old Feb 28, 2003 | 05:59 PM
prada_2o0o's Avatar
Default Re: ctr..orItr...??? (TRENDSETTLER)
with those ctr cams .. would you be able to use ITR springs and retainers or would you have to go all out ctr??
Old Feb 28, 2003 | 06:15 PM
rodrez.'s Avatar
Default Re: ctr..orItr...??? (prada_2o0o)
You can use your stock springs and retainers, I am. But if you want to rev it out using stock parts, ITR or CTR will work, doesn't matter.
Old Feb 28, 2003 | 09:57 PM
ABTDer's Avatar
Default Re: ctr..orItr...??? (rodrez)
ctr intake, itr exhuast
aznsins88
Jan 1, 2005 07:19 PM
B18C2_sedan
Apr 18, 2003 03:33 AM
Keepsake300ZX
Dec 25, 2002 03:42 PM
GS-Rcivic
Nov 12, 2002 11:16 AM
bboychris
Aug 18, 2002 09:41 PM
