cam gear question...
Old Feb 28, 2003 | 02:50 PM
silver5spd's Avatar
Default cam gear question...
my friend has a 96 civic ex, with the d series motor. the mods he has are exhaust and intake, at what position should he adjust the cam gear. he is going to have it dyno tuned but he has to save some money, so this is only a temporary solution.
thanks for your help
Old Feb 28, 2003 | 02:56 PM
Spade's Avatar
Default Re: cam gear question... (damn vw)
I wouldn't do anything until on the dyno. Just me.
He could advance it 1 degree....see how it feels on the butt dyno then make changes from there. Don't go to far in either direction without being on the dyno.
Old Feb 28, 2003 | 03:03 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: cam gear question... (Spade)
typically on the single cam, advancing the cam moves the powerband higher in the rpm range, and vice versa. But, since mods are little, change is not needed.
For instance, with my ZEX cam, I have it advanced 4 1/2 degrees. Anytime you do this, remember to re adjust the ignition timing, since it's adjusted with the cam.
Remember, all cam gears do is change the range of ponies on the rev graph. Where it gains you power, you will lose elsewhere.
edit- going with what Spade says, I would adjust more than 1 degree. Try adjusting 2 degrees in either direction. This will make it more apparent where you are gaining/losing power. And remember, adjust ignition timing with the new setting when the car is at operating temp with accessories off.
[Modified by Emerica, 4:05 PM 2/28/2003]
Old Feb 28, 2003 | 03:16 PM
silver5spd's Avatar
Default Re: cam gear question... (Emerica)
how do you adjust timing???
Old Feb 28, 2003 | 03:20 PM
Evs-One's Avatar
Solbros Owns Me
turn the distributor.
There will be 3 12mm bolts which hold the dist. onto the head. Loosen these up, grab your timing light, and adjust till you're on 16 degrees + or - 2 degrees: depending on what gas you're running, etc.
Old Feb 28, 2003 | 03:28 PM
silver5spd's Avatar
He runs 93 so where should we put it.......thanks
[Modified by damn vw, 12:30 AM 3/1/2003]
Old Aug 14, 2003 | 10:28 PM
spun Vtec's Avatar
advance = higher in the rpm's?
i read in another post retarding the cam timing is better for high end am i wrong?
it said:
retard=high end powerband
advance better bottom end.
so thats wrong?? just making sure whats right and whats not
Old Aug 14, 2003 | 10:45 PM
mycvc8u2's Avatar
Default Re: cam gear question... (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">advance = higher in the rpm's?
</TD></TR></TABLE>yea, i wanna know too
Old Aug 14, 2003 | 10:52 PM
MaxSterling's Avatar
Default Re: cam gear question... (mycvc8u2)
ignition time only affects low end torque....
advance timing make more low end power but generates more detonation/heat
retarding timing make less low end power but generates a more rich fuel mix and reduces detonation.
timing does not help high end
Old Aug 16, 2003 | 06:46 AM
spun Vtec's Avatar
Default Re: cam gear question... (RoyFokker)
bump
Old Aug 16, 2003 | 07:01 AM
Eee Pee's Avatar
Advancing the cam = power LOW
Retarding cam = power HIGH
Readjust IGNITION timing always.
tcwcrxhf
Oct 12, 2004 07:34 PM
b00stedbyFastrax
May 22, 2003 08:52 AM
accordexchange
Apr 3, 2003 06:17 PM
-Whitey-
Oct 10, 2002 04:02 PM
WannAbe_DC5
Aug 27, 2002 07:15 PM
