How do i reprogram my Keyless entry remote on my Honda Accord 2002
Old Feb 28, 2003 | 02:32 PM
240SXFORUMS.COM's Avatar
New User
Default How do i reprogram my Keyless entry remote on my Honda Accord 2002
I lost my remotes and i ordered some from ebay. I received the remotes but no directions on how to program them. I tried searching but came up with nothing. Can someone help me out? Thanks for all your help.
Old Feb 28, 2003 | 02:56 PM
Crono139's Avatar
Default Re: How do i reprogram my Keyless entry remote on my Honda Accord 2002 (240SXFORUMS.COM)
I had to get mine reprogrammed when I bought my car. I went to a local Honda dealer, and they did it for free.
Old Feb 28, 2003 | 03:00 PM
iam7head's Avatar
Default Re: How do i reprogram my Keyless entry remote on my Honda Accord 2002 (Crono139)
I was told i need a chip if i want an aftermarket alarm set up..but in this case you dont need to bypass the factory alarm system, just go to the dealer and have them do it..around 135 with remote and key(with chip)
iam7head's Avatar
Default Re: How do i reprogram my Keyless entry remote on my Honda Accord 2002 (iam7head)
my friend lost his keys and remote, that's why he's paying for it i guess
his car is ex 99 i thinnk
Old Feb 28, 2003 | 03:03 PM
bill-71SS's Avatar
sit in your car, turn your ign. switch to on, then press any button on only 1 of the remotes.then turn off key, Do it three times, on the third time you will hear your locks cycle, when you hear that, take your other remote and press any button,your locks should cycle,then do the first remote again,and you are done.
Old Feb 28, 2003 | 03:08 PM
New User
Default Re: How do i reprogram my Keyless entry remote on my Honda Accord 2002 (bill-71SS)
Thanks Bill that worked like a charm.. I knew it was easier than paying 135 hehhe. Thanks guys.
Old Feb 28, 2003 | 03:47 PM
Crono139's Avatar
Wow, you did all that, and were able to post a reply in 5 minutes. Are you The Flash, or something?
Old Feb 28, 2003 | 04:20 PM
iam7head's Avatar
LOL that fool actually pay 135 bucks for that bullshit..but he cant just cut the key right?
the key have a chip or somthing sh_t in it no?
Old Feb 28, 2003 | 05:12 PM
Crono139's Avatar
It's not worth it at all. Just get a remote start kit for $80. There should be the same controls on that remote as on the remotes given to you when you get the car. But then again, what do I care? My remotes work just fine, and they were reprogrammed for free.
Old Mar 3, 2003 | 04:13 AM
Stew Pidasso's Avatar
Bill, you are just plain amazing!!!
Old Mar 3, 2003 | 01:31 PM
v6illusion's Avatar
Crono139, won't work on 00+ accords because of the immobilizer. I had to get a special box that uses a relay and antenna with a key inside to make the immobilizer work(actually I just used some wire, wound it around the key a few times, then made a coil out of the other end and put it around the column, then put a relay inline so it only senses that key when I use the remote start).
Old Mar 3, 2003 | 10:20 PM
iam7head's Avatar
Default Re: How do i reprogram my Keyless entry remote on my Honda Accord 2002 (v6illusion)
Good info
edit: butta...didnt 240sxforum.com got it working on his 02???????????????????????????
[Modified by iam7head, 9:23 AM 3/4/2003]
toicy4ya
Audio / Security / Video
Apr 1, 2010 03:47 PM
ckjraj
Aug 8, 2007 07:19 AM
honda94accord
Feb 15, 2007 04:50 PM
wu4607
Mar 25, 2006 08:43 AM
97HondaSE
Jun 18, 2005 06:40 PM
