need help on si conversion on my dx
Can use the OBD1 injectors, just dont add the injector resistor box. The rest of the intake mani will work. You may have to do some coolant line routing and re routing but other then that it goes pretty well. Vacumn lines should be pretty much the same
what about ther wiring harness? do i use the one from the 95 civic or would it be better to get a harness from a hatch or crx si? what about the vtec do you know how that is wired up? also do you have any parts for the hatch? cause i need two fenders and a hood? thanks
EF9Lowlife
41
Mar 30, 2009 09:21 AM
MugenHonda
Jan 15, 2003 02:36 PM
