Hybrid "Type R" -- are these CR correct?
Old Feb 28, 2003 | 10:36 AM
Rust's Avatar
Default Hybrid "Type R" -- are these CR correct?
As some of you might remember, Im planning on swapping a b18c1 short-block under my b16a head. I will hopefully be reusing my JDM b16a sirII pistons. I am trying to figure out my CR but Im having trouble on the C-speedracing comp calculator. I dont know what to put down for the piston-to-deck height. I think I am supposed to select the b18 p2d height which would give me a CR of 11.3 but that seems awfully high to me considering the USDM b18c5's CR is 10.5. Is this CR right and if so, will I have to build up my block to handle something this high? Will my stock jdm b16a sirII int and exh cams work alright? TIA.
Old Feb 28, 2003 | 10:37 AM
Spade's Avatar
Default Re: Hybrid "Type R" -- are these CR correct? (Rust)
http://www.c-speedracing.com
How-to section has a compression ratio calculator.
Old Feb 28, 2003 | 10:57 AM
Nine's Avatar
Spade, that was the point of his post I think. He tried to use the C-speed comp calc but didnt know what to dial in.
Old Feb 28, 2003 | 11:55 AM
euclid's Avatar
Default Re: Hybrid "Type R" -- are these CR correct? (Nine)
i think that it will be thhat high if you are using b16 pistons, the b18c5 is almost 12:1 when ctr pistons are put in the block.... i could be wrong, but 11 sounds about right for your application.
Old Feb 28, 2003 | 12:04 PM
Rust's Avatar
Thanks for the replies. Can someone confirm the 11.3 CR I got from C-Speed? And if anyone knows about the other two questions, I'd appreciate the help there still. Thanks again.
Old Feb 28, 2003 | 12:27 PM
GapxGuy's Avatar
Sushi Buffet Champion
11.3:1 CR is correct, you'll be fine with those cams.
Old Feb 28, 2003 | 12:39 PM
Rust's Avatar
Default Re: Hybrid "Type R" -- are these CR correct? (GapxGuy)
Ok, thanks. Would I be able to run that high a CR w/o doing anything else to the b18c block? Here is my projected setup:
-Jdm b16a sirII Head
-B18c1/5 Shortblock
-Jdm b16a Pistons
-GSR Timing Belt
-GSR Head Bolts/Studs
w/ an AEM CAI, DC Sports 4-2-1 Header, Skunk2 Int Mani, 2.5" Custom Exh
I know u hate this kinda question but any idea what this might put down after its properly tuned. TIA.
Old Feb 28, 2003 | 01:02 PM
45psi's Avatar
yeah, would the b18 rods hold up to that high of compression, couple with a form of force induction?
Old Feb 28, 2003 | 01:11 PM
euclid's Avatar
Default Re: Hybrid "Type R" -- are these CR correct? (45psi)
if you are running 45psi, then you should build up the bock alittle
Old Feb 28, 2003 | 01:59 PM
Rust's Avatar
Default Re: Hybrid "Type R" -- are these CR correct? (euclid)
What do you suggest? Would a Golden Eagle BlockGuard be enough?
Old Feb 28, 2003 | 02:08 PM
GapxGuy's Avatar
You don't to do anything to the bottom end. Get your rods shotpeened for cheap insurance. With that setup and stock cams you should dish out about 155-170whp.
Old Feb 28, 2003 | 02:17 PM
Nine's Avatar
I think thats a pretty low estimate.. my jdm b16 made 151hp with just bolt ons..
I'd say you would be closer to 165-180whp with that setup.
Old Feb 28, 2003 | 07:15 PM
Rust's Avatar
Bump for opinions.
Old Mar 1, 2003 | 09:05 AM
TempBS's Avatar
Bump Again!
Old Mar 1, 2003 | 01:48 PM
Rust's Avatar
psegs80
19
Mar 6, 2006 08:30 PM
Pony_Fed95
Jan 18, 2006 11:10 AM
X_Ice_X
Jan 8, 2006 06:26 PM
dwchkypmp20
Dec 9, 2002 11:58 AM
SystemGSR
May 14, 2002 09:44 PM
