lightened crankshaft ??
Old Feb 28, 2003 | 12:16 AM
aeolus's Avatar
Default lightened crankshaft ??
Has anyone here used a lightened cranksahft on there h22a1???Was it worth the trouble??Any big differences in acceleration?Thanks!
Old Feb 28, 2003 | 03:36 AM
satan_srv's Avatar
Default Re: lightened crankshaft ?? (aeolus)
I had a knife-edged/lightened H23 crank. Acceleration was pretty nuts I was at 8500 rpms in no time. I also had a CM flywheel at the time...it was ridiculous...
Old Feb 28, 2003 | 04:35 AM
ejectseat's Avatar
Default Re: lightened crankshaft ?? (satan_srv)
who lightened your crank? KMS lightens and balances them for $425. Did you have any extra vibration w/ your setup?
Old Feb 28, 2003 | 05:52 AM
satan_srv's Avatar
Default Re: lightened crankshaft ?? (ejectseat)
That would be tough to isolate. I had forged pistons that slapped, lumpy cams, and an underdrive pulley. who knows really...
Old Feb 28, 2003 | 10:51 AM
Boostless97Lude
Guest
Posts: n/a
KMS ******* kicks ***, they did my crank, shave almost 7 lbs off, plus with that lighweight aluminum flywheel, revs so fast, i have like zero turbo lag
Old Feb 28, 2003 | 11:41 AM
satan_srv's Avatar
Default Re: lightened crankshaft ?? (Boosted97Lude)
The lightening and balancing on the H22a crnak I have only cost like 2 bills canadian...
Old Feb 28, 2003 | 12:04 PM
papa_smurf's Avatar
who did yours satan?
Old Feb 28, 2003 | 12:33 PM
satan_srv's Avatar
Default Re: lightened crankshaft ?? (papa_smurf)
A machine shop in toronto, likely Leitner and Bush, I just got it from the guy who runs Gilman Auto. He was going to put it in his F20B block but it doesn't fit. lucky for me.
Old Feb 28, 2003 | 04:43 PM
aeolus's Avatar
What about reliablity wise?Does it become a fragile peice once its lightened?Thanks !
Old Feb 28, 2003 | 08:00 PM
Boostless97Lude
Guest
Posts: n/a
no, the lightening doesn't really affect the srtuctural integrity, all it is doind is shaving the giant counterweights
Old Mar 1, 2003 | 10:20 AM
One Slow Lude's Avatar
Where is KMS located?
and about how long did it take them?....well basically how long were you without your car?
Old Mar 1, 2003 | 07:24 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: lightened crankshaft ?? (POSlude97)
KMS is in Covington GA, website is http://www.honda-performance.com ... i was without my car for about 9 months, but the crank was only gone for about a month..... now, just to pull out your crank and lighten it would be pointless, i was building my engine, so i twas easy, you will have to pull the engine and disassemble it to have the crank knife-edged
Old Mar 2, 2003 | 10:25 AM
satan_srv's Avatar
Well.....don't shave it if you are worried. I'd like to say it doesn't do anything, but you have to trust your machine shop. It has to be perfectly balance.
The main 'loss' so to speak is inertia. Off the line the car will not have much inertia to carry it forward, so you'll find yourself revving higher to get the car going cause once the clutch plate hits and the crank tries to turn the wheels the revs drop pretty quick. Upside is once the crank is moving it spins up much faster.
So on a track/highway/cruising power pickup is excellent
Old Mar 2, 2003 | 02:23 PM
sick boy's Avatar
thats kinda tru and kinda not, i mean you do lose the force but u dont loose much, when u hold ur rev at 2000 your motor is making power at 2000 rpm's and when u engage your tranny(drop ur clutch) ur still holding at 2000 untill u get traction so the power ur engine is making at 2000 stays weather u have a heavy or a light crank/flyweel/rim/ ect ect.
...and if u didnt get that. let me try to convince you this way. why do u want a 10 lb rim over a 20lb rim? less inertia, same reason we want lightend crank's and stuff. it takes less to turn the rim so therefore more power is transefred to the ground. so teqnicaly, rims "make" horespower just as much as pullys "make" power.
Old Mar 2, 2003 | 02:31 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: lightened crankshaft ?? (sick boy)
he's not saying anything about horsepower. hp stays the same. what satan said about the crank lowering inertia leading you to rev higher is completely true. it's physics. read SCC's last installment from project 300zx and you'll see that they picked parts like the clutch and flywheel assembly that were way too light for off-the-line times.
Old Mar 2, 2003 | 02:44 PM
satan_srv's Avatar
Default Re: lightened crankshaft ?? (PreIudeSI)
well I'll just dump it from 7000 rpms....no problems!
Ask S2000 guys, they will tell you how they have to clutch dump from 7000+ just to launch the car.
Old Mar 2, 2003 | 02:51 PM
BoostedH23a1's Avatar
is 425 lightened, balanced, and knife edged?
Old Mar 3, 2003 | 06:00 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: lightened crankshaft ?? (BoostedH23a1)
yes
Old Mar 3, 2003 | 07:24 AM
Default Re: lightened crankshaft ?? (Busted97Lude)
damnit not the **** keeps on adding up..
sleeves 900
rods 600
pistons 550
crank 465
gasket kit 300
oil pump 500 (new one with pro drive gear)
water pump 100
timing belt 45
grrrr
Old Mar 3, 2003 | 09:06 AM
da94ludesi's Avatar
You can take off too much weight on the crank. Those counterweights are there for a reason, and that is to counter the weight of the piston and rod.
Old Mar 3, 2003 | 12:45 PM
satan_srv's Avatar
No you are wrong dude. If you are holding the rpms at 2000rpms and engage the clutch it will BOG huge, the less inertia created by the lightened crankshaft will slow it down such that you will be pushing hard on the throttle to get it to get back up in rpms.
It does not transfer more power to the ground, all it does is allows you to move through your powerband faster. You make the same power, maybe you just think it is more power because you may hit your peak hp faster?
Old Mar 3, 2003 | 03:54 PM
sick boy's Avatar
yes u will bog at 2k with a lighnted crank over a non lightendd one, but were talking right off the line here, i would think a lighnted crank would im prove 60' times becasue the benifts of the extra power going to the ground after the first drop it, also i think its driving skill, getting to know how to launch w\ lightend stuff would take getting usda, maybe launch higer but let off for a second or something. who knows i dont have a lighned crank so i cant talk.
Old Mar 3, 2003 | 05:14 PM
Final Flash's Avatar
Verified. My best friend's dumping his 2k1 S2000 at almost 8K at the track just to get a decent launch; some other peeps recommend dumping it at like 8500. Sidenote/warning, he's getting his 2nd clutch put in this week at only 7500 miles.
Pablomg
May 13, 2019 03:16 AM
h22aBB4
Dec 14, 2006 01:47 PM
zx2gotboost
10
Mar 6, 2006 06:50 AM
H22Chameleonaccord
Jan 14, 2003 02:17 PM
