91 LX Blinking sports light?
I have a 91 accord lx and just dropped a f22a6+tranny into it. It runs great, but if i drive it for more than 1/2 hr and shut it off, when i go to turn it on it doesnt start. It turns over and the sports light in the bottom right flashes green. Then i disconnect battery, wait 5 minutes, and its fine. Could it be my ECU? It did this before i did the swap, thought it was tranny related...
It sure sounds like it may be ecu related. Disconnecting the battery probably forces the ecu to dump some bad data. I would start checking throttle and fuel delivery related sensors/systems.
Sorry I can't be more specific. The Honda factory manual (Helms) has a good deal of detail on the fuel delivery sensors/system.
[Modified by 97accordex, 8:46 AM 2/28/2003]
The odd thing is the speedometer works, it is about 3% over according to those radar boxes the police use...
I am still using the original motor harness for it, the one that came with the A6 had a different connector leading to the fuse box (a grey 5 pin instead of A1's red 6 pin). It is possible the harness is at fault, but all of the sensors on the motor I didn't touch. No one else has heard of this? Also, I added about a squirt of ATF to every cylinder to free it up, when this burnt off could it damage the sensor in the exhaust manifold? It smoked for about 2-3 minutes...
fry_guy12
Jun 5, 2006 08:32 AM
mussashimits
Oct 27, 2005 01:25 PM
BlazeTeck2000
Oct 3, 2004 09:58 PM
