Starting my swap on saturday...any suggestions???
Old Feb 27, 2003 | 08:34 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Starting my swap on saturday...any suggestions???
Well ive finally got everything i need and the weather is finally cooperating so im going to start on the swap this Sat. Im putting a 92 LS into a 90 CRX dx...im keeping it obd1 but ive already had the wiring done( to vtecrx...he did an awesome job on the wiring) so i dont have to worry about it. Do you guys have any suggestions to make this go by faster and a little smoother? Are there any sites that helped you guys out with the swap....like how-to sites? Thanks.
PS- How many quarts of MTF do i get?
Sean
Old Feb 27, 2003 | 08:55 PM
Louie B.'s Avatar
Default Re: Starting my swap on saturday...any suggestions??? (sCeRaXn)
the D trannies take 2 qts, i think the b's are the same, but someone else back me up on that.
#1 sugestion.... get backup transportation lined up for at least a week! there's always something that ends up slowing you down, no matter how well you plan things out. a perfect example of this is what I'm going through right now... https://honda-tech.com/zerothread?id=427602
"If you prepare for the worst, the worst won't happen."
Old Feb 28, 2003 | 03:46 AM
keithv's Avatar
Default Re: Starting my swap on saturday...any suggestions??? (thumpu77)
i think the b trannies are like 2.7 quarts on a rebuild and 2.3 on a change. i would just get 3 quarts...
Old Feb 28, 2003 | 05:22 AM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
2 Quarts of Redline MTL.
Good stuff!
Old Feb 28, 2003 | 06:52 AM
USDM 4G VTEC's Avatar
use right amount oil in the tranny, get plenty of food( u will get ******* munchies all the time)
bring a camera and take pics and show us....
dont rush urself and make sure u doble check all the stuff
if u get codes, fix them there... or u will not fix them for a while.....
dont rush and push it..... let it run for a lil bit and make sure everything tis ok before testing the engine its strong or not
Old Feb 28, 2003 | 07:53 AM
civbeater90's Avatar
Default Re: Starting my swap on saturday...any suggestions??? (USDM 4G VTEC)
i try to label and bag everything .this way nothiing gets missplaced.good luck.
Old Feb 28, 2003 | 05:18 PM
sCeRaXn's Avatar
Default Re: Starting my swap on saturday...any suggestions??? (civbeater90)
Well i went to the Acura place today to get some MTF and they were out....so i talked to a mechanic and he told me to get 5w-30 oil and its almost the exact same thing as MTF. Hes running it in his turboed prelude pushing 300hp so i guess its ok.
Thanks for all of the tips. My only problem now is that i might not be able to get a damn cherry picker(engine hoist). Ive read about putting the engine in from the bottom...do you guys know of any sites that has step by step instructions on this? I mightbe able to get the cherry picker around 1 in the afternoon so i might only have to take it out from the bottom.
Sorry to make this post long...but i have one more question. Does anyone know the torque specs for bolting the tranny to the block? I read in another post that it is 45-50 but that just seems too low. Thanks.
Sean
Old Feb 28, 2003 | 05:27 PM
Hybrid Invasion's Avatar
The only tip I can provide is that I heard that the LS sits a little bit higher than all B-series motors(someone correct me if i'm wrong on this one)so you might have to cut away some of the webbing under the hood where the cam gear cover is. Other than that, good luck, and let us know how it turns out!
On a side note- T minus 3 weeks and counting till my B16a swap begins!
[Modified by Hybrid Invasion, 9:28 PM 2/28/2003]
Old Feb 28, 2003 | 06:31 PM
CHRIS 1.8's Avatar
Just be patient and don't get frustrated and things will be a lot easier on yourself.
Old Feb 28, 2003 | 07:06 PM
do a searh here
breaka_1_9 is his name
do a search on his name....
he made a topi c a few weeks ago about that, with pics and a step by step....
Old Feb 28, 2003 | 10:19 PM
sCeRaXn's Avatar
Damn that was a sweet write up Thanks for the heads up on that one.
So does anyone happen to know the torque specs for attaching the tranny to the block? Or how much did you tighten it? Thanks
Sean
Old Feb 28, 2003 | 10:52 PM
Louie B.'s Avatar
45-50 sounds about right, remember, you're bolting aluminum to aluminum... you don't want to strip the threads out.
Old Mar 1, 2003 | 04:58 AM
sCeRaXn's Avatar
Thanks for all the help everybody. Im about to go start on it right now. Wish me luck.
Sean
rexracerboy
12
Feb 13, 2010 10:49 AM
madgeo
Jun 30, 2009 10:37 PM
CTR_B
22
Jan 30, 2008 10:48 AM
H23vtecEG
Jul 22, 2005 03:15 PM
sCeRaXn
Feb 28, 2003 05:24 PM
