h22 accord swap question
Old Feb 27, 2003 | 08:19 PM
misledyouth's Avatar
New User
Default h22 accord swap question
i am doing an h22 accord swap next weekend and i have two or three questions.
1. can i use the accord ac compressor?
2. what about accord ps pump?
3. accord throttle cable? can i make this work?
i made my d series one wokr for b series by rebending the plate that holds the cable.
4. what about cruize?
thanks jesse
Old Feb 27, 2003 | 08:35 PM
93accordh22's Avatar
Default Re: h22 accord swap question (misledyouth)
on my swap the a/c needed prelude lines and prelude p/s lines..... the throtle cable fit ok but is very thight... and cruize controle is hooked up... i havent tested it out cuz i still need to hook up v tech and a after market ignition
sean
Old Feb 27, 2003 | 08:44 PM
New User
Default Re: h22 accord swap question (93accordh22)
so you can't use the accord ac? i read you can. just not sure about ps.
also what's v tech?
just raggin on you man sorry hhaa.
jesse
Old Feb 28, 2003 | 03:00 AM
93acclude's Avatar
what year accord is it?
Old Feb 28, 2003 | 07:06 AM
New User
Default Re: h22 accord swap question (93acclude)
95or 94
Old Feb 28, 2003 | 08:33 AM
nickg11111's Avatar
on my 4th gen swap (90-93), i didnt hook up A/C (who needs it!?), use the prelude P/S (but youll have to get the P/S lines from a junkyard or wherever, the accord outlet line is too small, and the plelude inlet is too big for the resevoir hose), my throttle cable hooked right up to the prelude T/B (though the 5th gens dont have this convenience), and the cruise hooked up w/out a hitch (the cruise throttle cable goes to the pedal, not the T/B). good luck with the swap. oh, and you should also note that you have to use the accord fuel rail if youre swapping a JDM motor (inlet is on wrong side), and use the accord mounts (except for the tranny, and youll have to tap two new bolt holes on the prelude tranny). feel free to email me if you have any questions during the swap (i guarantee you will). have fun... (it's a blast!).
Bill danger
May 25, 2013 07:18 PM
PWRDbyHseries
Nov 14, 2006 09:33 PM
AccordRacing
May 23, 2005 01:31 AM
TurboLude97
Jul 20, 2004 07:55 AM
BIG ROB
Jun 5, 2002 09:34 PM
