Does anyone have pics of civic with integra radiator (lower and upper supports)
no pics for you, but I put an Integra GSR radiator in my 92 CX in one hour with just a dremel, some aluminum barstock and a few nuts and bolts. Got the used '99 GSR radiator from importautosalvage for $75 shipped! --->I just cut off my civic bottom mounts from the chassis, and bolted them on top of a 5" or so long piece of 1/4"x1" aluminum bar that had a hole drilled in each end. One end was bolted to the frame using existing threaded holes for the undertray/splashguard piece. The other ends were what I bolted the civic's bottom mounts to. Kind of like little cups that hold the rubber pieces the radiator sits on. Hmm, there was a link somewhere, here it is...
http://tech.hybridgarage.com/tech/jsrad/jsrad.html
wow thats a lot of work.... i figured since i already have a integra radiator with the fans and my new civic doesnty have a/c id go ahead and use this integra radiator. but seeing all that fabrication for judst a radiator then im just gonna use my stock radiator.
h22 civic
Welding / Fabrication
May 15, 2006 12:25 PM
JDM turbo DC
Mar 1, 2006 12:41 PM
lsvtec101
Nov 19, 2003 08:13 AM
