91 hatch w/b16 turbo fitting problems
Old Feb 27, 2003 | 06:46 PM
Vtecless212's Avatar
Default 91 hatch w/b16 turbo fitting problems
i have 91 hatch w/b16 drag 3 manifold garett t3/t4 turbo, but i had to run the intercooler piping through the core support. i now need to find a radiator that will fit. i have a fan just need a radiator. any help you can provide will be greatly appreaciated. thanks
Old Feb 27, 2003 | 07:40 PM
cutt's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (jdmturboef)
the radiator out of a 94 dohc del sol is a full size rad but half the length
Old Feb 27, 2003 | 10:57 PM
W0oT's Avatar
Banned
do a search for neon radiators in crx's or a 92-95 half sized radiator i'm told works
Old Feb 28, 2003 | 11:35 PM
kHoA DoGG's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (cutt)
no way. those half raditors will do the same amount of work to cool as the big chunky EF radiators? i'm going to look into this. Any fab that needs to be done?
Old Mar 1, 2003 | 07:48 AM
Full-Race Henry's Avatar
I had a lot of piping problems with my b16/t too. for a radiator, just get any 92-00 civic radiator.
Old Mar 2, 2003 | 05:20 PM
Default Re: 91 hatch w/b16 turbo fitting problems (EF8_Fan)
they say with the 92-95 civic rad the re bar needs to be chopped severly so i'm trying to keep it some what simple. my friend has a 92-95 civic with the stock rad and a smaller fan he runs 11.75 and has no cooling problems
Old Mar 2, 2003 | 05:50 PM
hatchii's Avatar
hmm i have seen some people here keep the 91 hatch radiator with turbo on their b16... i always wondered how they did it or which kit they used.
Old Mar 2, 2003 | 05:51 PM
Default Re: 91 hatch w/b16 turbo fitting problems (hatchii)
my intercooler piping goes straight through where the radiator is so i need a single radiator
Old Mar 2, 2003 | 05:58 PM
EF civic dx's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (sNoOziN' EF8)
why do you say that? my friend has a 95 hatch with a b18c1 and a drag 3 turbo setup with the stock half radiator it works fine
Old Mar 2, 2003 | 06:17 PM
FRESH's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (EF civic dx)
why not use a fluidyne or whatever they are called, in the half radiotor civic style one... im sure it would cool enough.
Old Mar 2, 2003 | 07:09 PM
1stealthls's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (FRESH)
hey i did a topic on rthis bout 2 weeks ago check it out
https://honda-tech.com/zerothread?id=417532
Old Mar 2, 2003 | 07:13 PM
USDM 4G VTEC's Avatar
k we know the biggeer the better the radiator
personally i think the EF ones are really good radiators.... my car never overheats and i even have the fan disconected
anyways.. liek they said try a del sol or 5G civic radiator...
if u way that the cut needs to be done.... what about the Neon radiator i keep hearing that fits??? personally i dont know a lot but i have heard that the neon's its small and fits
Old Mar 2, 2003 | 08:11 PM
Default Re: 91 hatch w/b16 turbo fitting problems (USDM 4G VTEC)
thanks for the help i guess i'll find out and let the next person who needs help know what works best
Old Mar 2, 2003 | 11:03 PM
hatchii's Avatar
my fan isnt working either and have been driving a year or so without it. Yet the car doesn't overheat unless i let the car idle for 15minutes or so. Fluidyne rocks.
Old Mar 3, 2003 | 06:01 AM
ricodemus's Avatar
May I ask what mounts you are using?
Old Mar 3, 2003 | 06:15 AM
Doodoo's Avatar
I don't understand how you routed your pipes so that your radiator doesn't fit...
Mine has a hole cut in the support at the drivers side of the radiator and my stock radiator fit fine.
I run a 92-95 civic Fluidyne right now and it was no walk in the park to fit in. But it works fine, better than fine actually.
Old Mar 3, 2003 | 06:47 PM
Default Re: 91 hatch w/b16 turbo fitting problems (Doodoo)
i'm running place racing mounts. and the reason i routed the piping through where the radiator goes is because it was either that or hack up the front crossmember and have the piping 1 inch of the ground
Old Mar 7, 2003 | 05:27 PM
Evil EG's Avatar
Maybe because his is a 95 and not a 91.
[Modified by BVM, 8:27 PM 3/7/2003]
Old Mar 7, 2003 | 05:40 PM
BoostedEF's Avatar
Do you have any pix of how you routed the intercooler piping? What intercooler are you using ? I just did the same thing on my car but I eliminated the washer bottle , made a hole and ran the piping there . I am also using a delsol radiator no problem.
Old Mar 7, 2003 | 06:00 PM
turborex's Avatar
Default Re: 91 hatch w/b16 turbo fitting problems (BoostedEF)
I have a 90 CRX with a b16a turbo and the Place Racing mounts and I ran my intercooler piping through the hole beside the rad, I had to make it a little bigger but it works fine and I used my stock rad
psikotc
Jun 22, 2006 04:44 PM
raymas8
Jul 13, 2004 03:11 AM
RussHondaCRXVtec
Nov 18, 2003 11:26 PM
VELOCITY R
10
May 18, 2003 11:23 AM
b16EF
Oct 21, 2002 12:00 PM
