problem with my throttle cable, using b16
Old Feb 27, 2003 | 04:36 PM
PhatHardy's Avatar
Default problem with my throttle cable, using b16
ok, now i know you are supposed to use the acura integra throttle cable, when doign the swap, but i thought i'd be cheap and save myself 20-30 bucks, so what I did was take the throttle cable holder thingy off of my d16a6, hook it onto the b16 throttle cable thingy, and bang the b16a throttle cable thingy down so it would be out of the way, but now, i'm having an idle problem and i don't believe it's because of vacuum lines, it seems that my idle stays around 2000-2500, but if i take the toe of my shoe and pull the accelerator up it goes down to like 1000 but when i let go it goes back up. So my question is, if i get an acura integra throttle cable, where can i get one of those bracketsthat hold it down, can i just grab on off of a integra at a junkyard?? Thanks
Old Feb 27, 2003 | 04:40 PM
RCautoworks's Avatar
Default Re: problem with my throttle cable, using b16 (PhatHardy)
Yeah but even with that bracket from an integra, it still won't open wot. Or you can go here
http://www.hcpengineering.com/ and order one for 10 dollors and you will be all set.
bk7794
13
Jun 21, 2012 08:17 PM
Scorchin Civic
Mar 12, 2010 11:05 AM
bseries_beast
Jul 2, 2004 09:25 PM
IVI
Apr 8, 2004 02:54 PM
integra99blue
Jul 16, 2001 07:56 PM
