91 accord 5speed same as 97 ????
here is the story i caled a junk yard the other day looking to get a tranny for my accord they said they had it and it was a EX tranny like i needed .... i went there and i wanted to see the car first and it was a LX not a EX so he proceded to tell me that there is no difference in them so i told him that i wanted the ex one or nothing so he got on the hot line and foind one for a 97 accord ex is there any differences in the 97 compaired to the 1991 all sensors the same ?? i have no tranny in my car as i bout the car without one so i dont know what #'s or codes should be on it ...
also he said he wanted 300 for it is that a fair price if not does anyone have a tranny that they can sell me ?????
have him knock 10% off for your trouble and his B.S. or threaten to walk
Edit: 94up trannies are usually in good shape with higher miles; Honda started using a synthetic base in their "from factory" tranny lubricants with a similar action to synthetic MTL.
[Modified by RotaryBzzz, 10:08 AM 2/28/2003]
what do you think about the gear racios will they be similar to the 91 ex trannys
how much should i expect to pay for a flywheel frm them ?? or how much should i offer ??
f22, f23, h23, h22 tranny's can all bolt up to each other. its only the gearing that is different. Clutch assembly and flywheel is also the same.
[Modified by h22accordvtec, 6:26 PM 3/5/2003]
h23 has a longer gear ratio similar to the F22. They say its better for the track. I personally would stick with the H22 tranny because you will get to VTEC faster. If you wanted to change the Gears of the H22 to be even more benifiting get a set of ATS final and first drive. you can IM exospeedamcrx for details and prices for any of the F and H series trannies.
f22 has the longest gears of all of them...as for your original question, the tranny will bolt up fine...and also, the ex and lx/dx trannies are so similar that you wouldn't notice the difference...the f/d is slightly different, but not enough to make worlds of difference...
