Hb Vs. crx?
Old Feb 27, 2003 | 03:02 PM
projecthybrid04's Avatar
Default Hb Vs. crx?
Roughly how much lighter is a CRX than an hatchback just stock?
Old Feb 27, 2003 | 03:40 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Hb Vs. crx? (projecthybrid04)
depends on the year
heaviest CRX a lil over 2200lbs
lightest hatch 1950 or so, the lightest CRX HF 88 can be striped down to about 1750lbs. depends on the year and make of model if you want light get a first gen civ or CRX.
Blaze
Old Feb 27, 2003 | 04:03 PM
Default Re: Hb Vs. crx? (Blaze45)
Let me be more specific, 88-91 hb weight Vs. 88-91 crx???
Old Feb 28, 2003 | 09:15 AM
4potnick's Avatar
If i am not mistaken i think that a 88dx hatch is lighter than a 91si crx.
Old Feb 28, 2003 | 04:56 PM
thecorey's Avatar
i just weighed my b16 crx si today...2055lbs...not bad huh? its basically stock...cept stripped AC system...and stripped the interior out of the back...and of course the B16 added some weight
Old Feb 28, 2003 | 05:04 PM
Hybrid Invasion's Avatar
Default Re: Hb Vs. crx? (thekori)
What year is your si, if you don't mind me asking?
Old Feb 28, 2003 | 05:09 PM
EFing8's Avatar
Default Re: Hb Vs. crx? (Hybrid Invasion)
my 88 CRX HF - 1815lbs
Old Feb 28, 2003 | 05:21 PM
Default Re: Hb Vs. crx? (EFing8)
well I was actually asking thekori, but I almost want an HF now... instead i'm stuck with the bastard child of the EF world; the DX
Old Feb 28, 2003 | 08:26 PM
_BURN_'s Avatar
88 crx si down to 1890 with lst
Old Feb 28, 2003 | 10:08 PM
Mediademics's Avatar
If its any help you can go to http://www.autotrader.com and click on research and compare. You can get model info on any car new or used.
Old Mar 3, 2003 | 12:41 PM
thecorey's Avatar
88 crx si
Old Mar 3, 2003 | 01:10 PM
baggelis's Avatar
1991 CRX SI stock
2174lbs
1991 Civic HB SI stock
2284 lbs
[Modified by baggelis, 8:24 PM 3/4/2003]
Old Mar 3, 2003 | 01:31 PM
FullMetalJacket's Avatar
Default Re: Hb Vs. crx? (baggelis)
wouldnt a STD hb with b16a weigh almost the same as a Si with a b16a since the things that really make the hb lighter are smaller hubs,4speed instead of 5 speed..and no rear wiper..Im sure a STD would still be like 60lbs..
Old Mar 3, 2003 | 01:42 PM
CLICC916's Avatar
2338 lbs=1990 civic si with b16a+full interior+two 8" subs with box
sometimes i wish it was 200 lbs lighter...
[Modified by CLICC916, 2:42 PM 3/3/2003]
Old Mar 3, 2003 | 01:57 PM
Default Re: Hb Vs. crx? (CLICC916)
it would be if you took your subs and rear interior out when you race well... maybe not quite..
Old Mar 3, 2003 | 02:06 PM
keebler65's Avatar
where did you go to get it weighed??? did it cost anything?
Old Mar 4, 2003 | 09:46 AM
thecorey's Avatar
Default Re: Hb Vs. crx? (keebler65)
i went to the landfill...it was free.
Old Mar 4, 2003 | 02:19 PM
Thats cool, i'll prolly get mine weighed soon!!!
Old Mar 4, 2003 | 08:44 PM
StorminMatt's Avatar
It's hard to compare weights since there are alot of variables. For instance, the lightest 1988-1991 CRX is lighter than the lightest 1988-1991 Civic HB (1988 HF at 1819 pounds vs 1988 STD HB at 1989 pounds). But things can get very complicated for alot of reasons. For instance, the 1991 CRX SI is lighter than the 1991 SI HB. BUT the 1989 SI HB is lighter than the 1989 CRX SI. The reason? 1989 Civics did not have door mounted seatbelts but 1989 CRXs (except HFs) DID. And, of course, newer CRX SIs weigh more than any of the older HBs. A good rule of thumb is that CRXs are lighter than HBs of the same year AND trim. Except for non-HF 1989 CRXs.
Old Mar 4, 2003 | 08:50 PM
essex's Avatar
Default Re: Hb Vs. crx? (StorminMatt)
https://honda-tech.com/zerothread?id=432797
Old Mar 4, 2003 | 09:40 PM
im pretty sure the 89 hb weighs more than 89 crx..the belts dont make it weigh any more..its the door reinforcement bars that all 89-91's got..seat belts dont weigh 100lbs..
Old Mar 4, 2003 | 11:09 PM
itr-j's Avatar
Default Re: Hb Vs. crx? (FullMetalJacket)
hatches are like economy but still look good
Old Mar 5, 2003 | 04:35 AM
89civicdx's Avatar
try the hatch, the crx hatch is a bitch to lift with no shocks its gotta be way heavier than the civic hatch
Old Mar 5, 2003 | 04:06 PM
Default Re: Hb Vs. crx? (89civicdx)
Tru thehatch is heavy on a crx but dont forget all the xtra metal a hatch has its wheel base is like 4 or more inches longer and more metal on the roof....backseats etc..that stuff adds up
Old Mar 6, 2003 | 08:10 PM
But the move to door mounted seatbelts made the reinforcements necessary.
