UR Crank Pulley on DOHC ZC...
Old Feb 27, 2003 | 09:58 AM
SloCivicHMM's Avatar
Default UR Crank Pulley on DOHC ZC...
How about it??
does my crank have a harmonic balancer?? can I use a pulley it...should I use it?? I've heard stories....did a search and I just want more opinions....
will a d16z6 pulley work on my car???
[Modified by SlowCivicHmm, 7:01 PM 2/27/2003]
Old Feb 27, 2003 | 10:04 AM
Steve91's Avatar
Default Re: UR Crank Pulley on DOHC ZC... (SlowCivicHmm)
Do you see any type of rubber ring in the pulley? That's a sure sign of it being a harmonic balancer. I know for a fact that on the D16a6 that the oil pump is the balancer and not the pulley. I've been running a Unorthodox Racing pulley on my D16a6 for 2 years and no problems. My buddy runs one on his 85 SI (stock motor) and his runs great too.
About the only negative with this pulley is that the clutch is more sensative. With a 14oz. crank pulley and my 9lb. flywheel, the clutch is engages very quickly. I guess thats to be expected when you take 13lbs. of rotating mass off the engine.
Old Feb 27, 2003 | 10:05 AM
DJ_SaNdOz's Avatar
Default Re: UR Crank Pulley on DOHC ZC... (Steve91)
honda's are internally balanced; they don't use a harminc type pulley. i've had mine for almost a year w/o problem; throttle response is way better.
Old Feb 27, 2003 | 10:09 AM
djhankb's Avatar
the ZC uses a stamped out Pulley very similar to a DX or HF CRX... so I wouldn't see a problem with the UR pulley
the A6 has the big rubber piece in it..
-Henry
Old Feb 27, 2003 | 11:55 AM
Hayasa15's Avatar
Default Re: UR Crank Pulley on DOHC ZC... (djhankb)
what about the z6? is the crank pulley the harmonic balancer or is it internal also? i have a z6 motor but it didnt come with the pulley so i was wondering which to use? also is it true that your crank pulley and alternator most be for the same motor or else the belts wont work?
Old Feb 27, 2003 | 12:29 PM
SEA Hag's Avatar
Default Re: UR Crank Pulley on DOHC ZC... (Hayasa15)
The rubber in the crank pulley is because the alternator , PS, And Ac belts put strain on that end of the crank. The rubber helps releive some of the pressure. The pulley itself, at least on a B series engine is balanced.
Old Feb 28, 2003 | 11:11 PM
Hayasa15's Avatar
Default Re: UR Crank Pulley on DOHC ZC... (SEA Hag)
ttt
Old Feb 28, 2003 | 11:28 PM
Steve91's Avatar
I believe the Z6 pulley is the balancer
Old Feb 28, 2003 | 11:30 PM
Louie B.'s Avatar
I sold my UR style (ebay special) pulley to a guy with a ZC and he said it didn't fit because the keyway was different.
I ended up selling it because I saw pictures from people of destroyed main bearings from running them. But then again, I have a d16A6 which has a harmonic balancer.
HatchbackCivicPR
Feb 20, 2006 08:45 AM
D21X
12
Apr 25, 2005 02:07 PM
SloCivicHMM
Aug 6, 2003 07:41 AM
quis23
Jul 14, 2003 10:40 AM
