a new sterring wheels (install)
Old Feb 27, 2003 | 06:13 AM
wm5holla's Avatar
Default a new sterring wheels (install)
how do u install a sterring wheel? on a eg!
Old Feb 27, 2003 | 06:35 AM
racecarpete's Avatar
Default Re: a new sterring wheels (wm5holla)
It's extremely easy man.
1) Disconnect battery
2) Pop small panels around the steering wheel off, there will be 2 or 3 dependent on whether you have cruise control.
3) On each side behind these plastic panels is a torx screw. I forget the size. Unscrew these two, and disconnect the airbag plug and take airbag out.
4) disconnect anything else you see. ie horn whater
5) loosen main steering wheel nut, i think it is a 19 or 20 mm.
later
Old Feb 27, 2003 | 06:38 AM
wm5holla's Avatar
Default Re: a new sterring wheels (SilverCivic2k)
thanxs man . im just scared if i try and i screw it up. i wont be able 2 drive it to a shop and get it fixed!
Old Feb 27, 2003 | 07:35 AM
Pengo's Avatar
its not difficult. u may wanna read up the SRS section in the manual to learn how to properly disconnect the airbag plug and put on that clip so that it doesn't accidentally deploy. the screws holding in airbag are T30 and the big nut should be 19mm. good luck
Old Feb 27, 2003 | 07:44 AM
wm5holla's Avatar
Default Re: a new sterring wheels (Pengo)
good man
BLacK FirE
Apr 23, 2016 08:53 PM
DC5mike
Jan 12, 2008 08:15 PM
spooneg8
Dec 18, 2006 12:58 AM
phoshizzle88
Sep 12, 2006 07:46 AM
UndergroundVR-4
Mar 22, 2003 09:57 AM
