What's the best bang for the buck rim in a 16x7 size on the lighter side?
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
What's the best bang for the buck rim in a 16x7 size on the lighter side? I could care less how they look or the brand, but I would like it to weigh in under 15lbs. and for them to be able to handle some abuse.
Rota Slipstreams would be your best bet considering your price range... I think you can pick up four wheels 16x7 and weigh about 12.5-13.5 lbs w/o tire for $500 shipped... Maybe less, depends on where you find em...
I guess I'll go with the rota's, so where's the best place to pick them up at?
The rota slipstreams in 16x7 weigh 14lbs., What do the Kosei K1's weigh in a 16x7 rim size?
i think they have them on special for 5 lug...
and it says they're 13.5 lbs...
i have seen the gunmetal color in real life and it is kick *** imo...
it's more like a dark gunmetal/bronze color. real dark...
it was on a black gsr...looked good...
Guest
Posts: n/a
What are the offset 'limits' you want to stay within btw. +35-45? Would 45 make the wheel go in too much? Happened to stumble on a set of evo's with a +45 offset for 2200 shipped. Did I mention they were 17s..
you can use https://honda-tech.com/zerothread?id=364614 for bit more details
or http://toy4two.home.mindspring.com/offset.html does it for you.
What offset should I get in a 16x7 rim size?
I don't thnk they make 16X7 ssr comps for type-r's 5x114.3... correct me if I am wrong, if so I'll be all over dat
