anyone ever seen an S1 w/ factory LSD?
Old Feb 26, 2003 | 05:56 PM
Jared's Avatar
Default anyone ever seen an S1 w/ factory LSD?
I have a cable trans that I'm trying to identify. According to the tooth counts it has a 4.40 FD, but it has a 90-91 splined inputshaft. It is stamped LSD but the LSD has been robbed from it. Doing simple math to determine ratio of input shaft vs output shaft, its geared like an S1 or YS1 rather than a Y1. Any suggestions on this one?
[Modified by Jared, 2:57 AM 2/27/2003]
Old Feb 26, 2003 | 07:31 PM
Malgerus's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (Jared)
Hmm that's interesting. I'm 99.9 percent sure that there were no LSD equipped S1/J1 trannys. Bump for you!
Old Feb 27, 2003 | 01:09 AM
smokey2.0's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (Mr. S)
at one point, i saw a web page that stated that there were two types of Y1 trannys. the first type or gen, was the one with the 4.26 fd with the lsd. the second type, had a 4.40 fd and gearing like a S1! try getting a Y1 lsd diff, and test fit it!
Old Feb 27, 2003 | 01:17 AM
REX VT's Avatar
Never heared of it, perhaps the LSD stamp was to raise the price? :D
I found a cable Y1 LSD (scarce as hell) in Japan but unfortunately it was sold
Old Feb 28, 2003 | 04:16 PM
Jared's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (smokey2.0)
That's VERY interesting, do you remember the site?
Old Feb 28, 2003 | 04:17 PM
Jared's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (REX VT)
Thats a possibility since it has no sticker, but I was told before I got the trans that it had no LSD, and by the Hondabond, someone has been in this after the factory sealed it, so theres no way to tell, hell, it could be a S1 gearset in a Y1 case half.
Old Feb 28, 2003 | 04:18 PM
bryant's Avatar
No S1/J1 ever came with factory LSD.
Old Feb 28, 2003 | 04:25 PM
Jared's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (Bryant)
New find, after counting teeth, apparently, I have a trans that has been modified. I have an S1 FD, S1 2st, but 2nd-5th are Y1. Odd.
altoid's Avatar
look through the holes where the axles go through(differential), if you can see through no obstuctions its got an lsd
Old Feb 28, 2003 | 04:26 PM
Jared's Avatar
Default Re: anyone ever seen an S1 w/ factory LSD? (EE4)
If you'll notice, I said it no longer has an LSD, I have the case halfs split and its on my workbench.
Old Feb 28, 2003 | 06:24 PM
smokey2.0's Avatar
i looked through my favorites, and i could not find the website. i must have trashed it!
boosted94teggy
Apr 25, 2006 01:26 PM
Mattamotor
Jun 8, 2004 06:59 PM
jDMJeRk
Dec 23, 2003 07:31 PM
CR-V-tech
Oct 29, 2003 05:37 AM
