cheap ass turbo setup??
My buddy has a 91 civic dx. Hes looking for cheap power. I was thinking a cheap custom turbo kit.
d series turbo manifold go for under a $100 on ebay and t3 turbos are a dime a dozen at scrap yards.(volvos)
A cheap intercooler and a FMU to add fuel. We wouldnt go past 5 or 6 psi.
where can I find a rising rate fuel pressure regulator for the D15 engine.
will he need a better fuel pump?
um that sounds ok do a search for more info but a FMIC will help keep deatonation down and you dont really need a FPR with a FMU cause you fuel pressure will aleready be high engough. you dont need a fuel pump. i would suggest a SMC and some 450ccs is prolly you best bet...
Blaze
Blaze
go DPFI to MPFI $200
MSD 6A BTM $315
HF manifold $50
adapter to turbo $75
custom downpipe, and catback $350
Vortech FMU 12:1 $140
MAP check valves $20
Turbo $50
misc parts $100
and more minor parts $???
MSD 6A BTM $315
HF manifold $50
Turbo $50
misc parts $100
there is a pic lingering around on here of a DPFI turbo. The intercooler was WRX style. I tried to search for it, but no luck. i would suggest doing he MPFI swap or at least adding extra injectors.
look to pay more around 150 for a turbo. 50 dollars maybe from a local wrecker, but most 50 dollar turbos need a ~200 dollar rebuild.
Turbo $50
Turbo $50
i used my quote..
i can get turbos with no shaft play for $50 from my buddy .....
5thgentdo4lude
Oct 20, 2005 09:08 AM
to your face
