D16a6 gas feedline bolt to Y8 fuel rail?
Old Feb 26, 2003 | 12:33 PM
1.8Tities's Avatar
Default D16a6 gas feedline bolt to Y8 fuel rail?
Well, i'm doing a Y8 intake swap and i would like to know if the A6 gas feedline bolt will fit the Y8 fuel rail? Input will be greatly appreciated.
Old Feb 26, 2003 | 01:17 PM
1.8Tities's Avatar
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (4thGSi)
just one bump for me.
Old Feb 26, 2003 | 01:59 PM
d357r0y's Avatar
no, it wont.
BUT... the 88-91 d15 fuel line will
thats what i used
Old Feb 26, 2003 | 04:55 PM
Vinceg99's Avatar
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (d357r0y)
no, it wont.BUT... the 88-91 d15 fuel line will
thats what i used
Thats good to know!!
Old Feb 26, 2003 | 05:11 PM
turbo sol's Avatar
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (Vinceg99)
what about a a6 fuel line and a z6 fuel rail?
Old Feb 26, 2003 | 05:12 PM
1.8Tities's Avatar
no, it wont.
thats what i used
Thanks man.
Old Feb 27, 2003 | 02:03 PM
turbo sol's Avatar
does anyone know my answer?
Old Feb 28, 2003 | 08:25 PM
photonjedi808's Avatar
My friend and I just did the swap and it did bolt up
you have to use your A6 injectors if you're still using the A6 (PM6) ecu
When we plugged in the A6 injectors and pressurized the system the O rings leaked
So what we did was swap out the O rings from the Y8 injectors and that solved the problem
Old Feb 28, 2003 | 08:26 PM
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (photonjedi808)
Oh and also if you're using the Y8 FPR you have to extend the fuel line
Old Mar 1, 2003 | 07:08 AM
1.8Tities's Avatar
Awesome, I was kinda worried the diameter of the A6 fueline bolt is bigger. So i guess I'm good to go with my project. Thanks man.
Old Mar 1, 2003 | 12:25 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
ok, so is that one NO and one YES? so will it work or not? i saw this thread when it was NO it wont work so i went out and got a fuel line from a 92 civic d15??. and the fuel rail looked the same as the Y8 one. also the fuel line is a little longer than the 88-91 dx fuel lines. oh well...if the answer ends up being yes than i only wasted 3 bucks. at least the hole in the fuel line lines up perfectly with the hole in the rail.
Old Mar 2, 2003 | 06:30 AM
1.8Tities's Avatar
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (fastcrxsi90)
Only thing we could find out is you to try it out first. I was planning doing this swap this week but it fawkin cold, so i have to wait for a warm weather to do this. Get back to us if your doing it. Thanks
Old Mar 2, 2003 | 06:39 AM
USDM 4G VTEC's Avatar
no, it wont.
thats what i used
how come a D15 will fit perfect into a A6 line but the A6 will not into the D15?
i have done quiet swaps and help in alot... we have never enountered problems.... even on B series engines....
maybe u just missed the lil washer that needed to be installed in the line before u put the cap bolt........ the A6 has 2 lil nipples that hold the line on a certain angle... thats so the line doesnt get twisted..... my STD worked fine on the Z6 rail with no problems//// and yes a friend put a Z6 into a A6 fuel line feed and worked fine.....
Old Mar 2, 2003 | 07:03 AM
d357r0y's Avatar
Default Re: D16a6 gas feedline bolt to Y8 fuel rail? (USDM 4G VTEC)
take a look at the end of the D16 line where it bolts to the fuel rail and then compare it to D15 line where it bolts to the fuel rail (throttle body??) and you will see how they are completely different.
Old Mar 2, 2003 | 07:13 AM
1.8Tities's Avatar
Dang which is which!? If you guys can post some pics it will help alot..
MUGENVX9
Honda Civic (2001 - 2005)
Aug 9, 2013 10:59 AM
turboDeznutz
Jan 4, 2008 11:39 AM
vegaskurt
Apr 22, 2005 02:26 PM
KamikazeRacinz
Apr 22, 2004 06:56 AM
1.8Tities
Nov 21, 2002 11:04 AM
