Camber kit need???
You may well need Camber kits and they are not really that expensive. It is possible to do the rear with the longer bolt/washer method--depends on how far out of spec you are. The front will need kits from one of several companies like Ingalls or Specialty products-again depends on how far out of spec you are.
The biggie here is to get the car aligned as asoon as possible after lowering and get the printout. That is the only way you can know for sure what you will need when looking in the catalogs.
k i just got myself camber kits from Ingalls....
i did quite a few searches and post/... not a lot of luck, until i PM like 5 people....
all i gotta say its that the best deal u are going to get its the Ingalls Xtreme anchor adjustable bushings....
found them in http://www.iapdirect.com they got the ingalls kit for $130 shipped for both sides..... a lot of places jsut sell u one side only....
