B series into Civic 4 questions
swap into 91 civic std
1. When i use civic ex knuckles i will also use the calipers (bigger and better) so what should i do about lines? same diameter and length as mine?
2. Should i use a new brake cylinder too then? if so what one?
3. for now can i get the stock std exhaust to hook up to a b series exhaust mani?
4. Stock STD radiator for a while ok?
Thanks
Thanks
the radiator is fine.. the exhaust u might be able to rig something but u should just have someone bend u one. the b needs a bigger pipe. and i am not sure but i think the brake lines are fine... and the master cylinder will work too. where u get your ex hubs!? i want em!
1. Lines should be fine.
2. You don't have to, it's up to you. CRX Si is good, and also the Civic Ex.
3. I'm not sure about the exhaust, but I believe you can.
4. Radiator will be fine, unless you start to boost, or run higher compression.
denniscoles
Mar 13, 2008 08:05 PM
FourthGenHatch
Jun 22, 2003 09:04 PM
