What is the cheapest way to stop burning rich!!!
Old Feb 26, 2003 | 09:27 AM
kay_animation's Avatar
Default What is the cheapest way to stop burning rich!!!
Arright, I have a 1994 honda civic ex coupe. My engine mods are RS*R 4-2-1 one piece header, custom ( ) 2.25" catback exhaust, and a 2.5" CP cold air intake. Autozone sparkplug wires, and bosh duel spark plugs. Everything else is stock. The problem is, I am burning rich and I thought that when I put the header on, I would at least be burning lean, but I'm still burning rich. I reset the ECU and everything, but still very rich. I get hella black stuff all over the back of my car, and the exhaust smells like gas. I tried to fill up and count my mileage and I think I get about 220-240 mile to a fullup. PLEASE HELP. I'm tired of cleaning the back of the car, buying gas, and smelling gas while I'm driving.
Old Feb 26, 2003 | 09:30 AM
jdmsol's Avatar
Default Re: What is the cheapest way to stop burning rich!!! (kay_animation)
Hmmm....sounds like me except I get a little better gas milage. Black rear bumpers
Old Feb 26, 2003 | 09:32 AM
splitime's Avatar
There is probably something else wrong with your setup. But you could lower fuel psi with an FPR. B&Ms fpr sells for like 30-40bucks, Heres the groupbuy special Titan is offering. https://honda-tech.com/zerothread?id=395640
[Modified by splitime, 10:34 AM 2/26/2003]
Old Feb 26, 2003 | 09:42 AM
I guess I can do that. Is it ok to lower the FP without knowing the fuel to air ration? If so, when I buy a fuel pressure regulator, what should me fuel pressure be set at? I'll be setting it at idle, (of course ).
Old Feb 26, 2003 | 11:48 AM
pennies_hatchie's Avatar
i had the same problem, every other 4 seconds (when not driving) it would backfire. went out and got a vafc, that took care of the problem
Old Feb 26, 2003 | 11:53 AM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default Re: What is the cheapest way to stop burning rich!!! (pennies_hatchie)
what is an estimated amount of miles is a civic ex supposed to get per fillup?
Old Feb 26, 2003 | 12:12 PM
Briman2021's Avatar
Default Re: What is the cheapest way to stop burning rich!!! (iluvjasmine)
my 97 ex coupe with I/E can get around 300 if i drive like an old man, but usually around 275-285
When i had a check engine light, and my car was running really rich, it was getting about 250 per fillup.
Old Feb 26, 2003 | 12:17 PM
White Lightnin's Avatar
Default Re: What is the cheapest way to stop burning rich!!! (Briman2021)
Is your o2 sensor good?
Old Feb 26, 2003 | 12:32 PM
43MA's Avatar
Default Re: What is the cheapest way to stop burning rich!!! (White Lightnin)
create a huge vacuum leak like unplugging the vacuum booster
running rich all the time will kill your cat in no time.
get it fixed asap
Old Feb 26, 2003 | 12:35 PM
martini's Avatar
Default Re: What is the cheapest way to stop burning rich!!! (Steady)
first try something as simple as cleaning your injectors. Run some injector cleaner through it if oyu haven't recently.
Old Feb 26, 2003 | 10:20 PM
Default Re: What is the cheapest way to stop burning rich!!! (martini)
damn i get around 230. 250 if im lucky i always thought this was normal.
efjones9
13
Sep 11, 2008 09:01 PM
jjr_99prelude
Apr 24, 2008 12:37 PM
kay_animation
Mar 11, 2003 08:04 AM
SoNNyBoY9o9
Nov 3, 2002 01:50 PM
b16awarrior
Sep 26, 2001 11:14 AM
