Injectors & valves in a b16a1 engine?
Old Feb 26, 2003 | 01:11 AM
Micke Mugen's Avatar
Default Injectors & valves in a b16a1 engine?
Hi there! Do enyone now if I need to change injectors and valves if I`m gonna turbo-charge my engine?
I will use a Mitsubishi Td-04 hl 16T turbo. With a 8.0:1 compression-ratio.
(I`m from Sweden, so it can be some bad spelling)
//Micke.
Old Feb 26, 2003 | 04:07 AM
EP3_05's Avatar
Default Re: Injectors & valves in a b16a1 engine? (Micke Mugen)
You will need to run larger injectors and some sort of engine managament system to control the larger injectors. Check out the Forced Induction board. There is an enormous amount of info about basically every type of engine management system. Good Luck
Old Feb 26, 2003 | 04:18 AM
ricodemus's Avatar
//Micke.
yeah, search for "b16 turbo" or something in the FI forum and read up. There is a lot of information in there that you could learn. But yes, I would definitely upgrade the injectors, how large depends on what kind of power you're trying to make.
Old Feb 26, 2003 | 05:20 AM
Thanks guys!
That means I don`t need to change valves, right?
Old Feb 26, 2003 | 05:45 AM
Rob!'s Avatar
wOw
Old Feb 27, 2003 | 02:49 PM
What injecyor size do I need at 250hp?
afnan
Jan 15, 2014 11:00 AM
DUB20VT
Nov 29, 2004 04:10 AM
h22civic95coupe
Jun 29, 2003 09:38 AM
koco
Feb 20, 2003 12:03 PM
fastludeh22
Nov 5, 2002 11:29 PM
